Found this sitting next to spark plug on head - any guess what it is?
  • ThrottleJunky
    • Jan 2011
    • 183
    • PNW
    1980 XS1100G. Work in progress.
    1980 XS1100G. 2nd work in progress.
      Do tell...part of a welding rod?
      • Old Red
        • Jul 2012
        • 290
        • Greenville, NC
        Has any valve work been done on the head? It looks like a pilot for a valve grinding stone to run on.
        Earl
        80SG, 81SH, 80 standard parts bike, 81SH parts bike
        and new to me 78 standard dresser
        • ThrottleJunky
          • Jan 2011
          • 183
          • PNW
          I found this on "Bike #2." I have absolutely no clue what it is. It comes apart into two pieces. I don't know if any valve work has been done to this motorcycle. I do see evidence of gasket seal leaking down the head.
          I do know that whoever was working on it should definitely STAY AWAY from tools. The carbs were way out of adjustment - one mixture screw was almost completely bottomed out, the next one out over 5 turns, with heads mangled. Number 2 pipe is blue all the way from the header to over half way down the pipe. The bike wouldn't even idle or really run.
          There is a 7/16" socket stuck on the oil filter bolt head (which is presumably stripped out).
          I have it extremely really well, now.
          • ThrottleJunky
            • Jan 2011
            • 183
            • PNW
            *have it RUNNING extremely well, now.
            No edit button here?
              As I remember, that should be a 12mm head. I would see if it rotates at all, and if so (and you are lucky), get a replacement filter bolt.
                There is a 10 minute Edit time limit on posts. There is a PREVIEW button that will allow you to Proof Read a post before final submission,and you can then edit it there.
