Valve bucket (lifter) issue
  • mmaddix
    • Jul 2011
    • 232
    • Beaufort, SC
    I'm looking for some expert opinions... I couldn't find any so I came here
    So after putting a head back on a motor I guess I didn't lube everything up enough. One of the valve bucket (lifters) doesn't come all the way up so it is creating a tapping noise from the can hitting it. I'm just trying to see if you guys think since it didn't completely come up do you think it allowed the valve to hit the piston? I know the only way to know for sure is to pull the head.
    I'm going to pull the cam pull the valve bucket out try to clean it up and clean up the whole it goes into to see if I can get it to come up completely. Maybe part of the problem is a weak valve spring?
    I appreciate all the input in advance.
    USMC 2005 - Present
    79 XS1100F -Mileage unknown - Clubman bars, aftermarket headlight and speedometer, 4 into 1 straight through exhaust, TopCat's fuse box, 1980G rear fender - Daily driver - My first Motorcycle
    78 XS1100E - Rebuilt And Sold I SHOULD OF KEPT IT!!!
    • 2053
    Uh oh
    I hate to say it, but it smells like a bent valve.
    Easiest way to tell is a compression test of that cylinder.
    • vedgar
      • 311
      • Clarkston, Michigan
      bent valve
      I second that motion .
      79 1100 SF Carmine Red stock
      85 Honda v65 Magna
        I third that motion.
        • mmaddix
          • Jul 2011
          • 232
          • Beaufort, SC
          I can't believe I didn't think to test the compression.
          I got the bucket to move up and down freely but I still have some valve train noise. It probably is a bent valve. I'll run a compression test on it and see what it looks like.
          Thank you everyone for the replies.
          USMC 2005 - Present
