right side blinker not working
  • jimg1au
    • 102
    • sydney australia
    hi
    while riding to work last friday i noticed the rhs blinker not working.today pulled switch apart and cleaned.voltage to both wires.the flasher can is from a car and when i check for voltage only the side that works lhs has voltage when switched.
    any clues wiuld be good as i am not good with wires as i am red/green colour blind.
    thanks
    jim garvey
    1 x xs1100h
    2 x xs1100rh
    1 x it400f
    Hey there Jim,
    You don't have to worry about the red green problem. The path of the current from the handlebar switch is to the wires that go to the lights, and to ground, throwing the switch just enables the circuit to complete it's path to ground. You know your LHS set is working, so your blinker is also working, but with an improper ground, your RHS won't blink. Pull your bulbsand check for blown bulb, check the contacts, also the ground wires around the signal stalks going to the ground plugs for that side, you'll probably find a poor ground, once it's fixed/cleaned, the signals should work again!!
    • thumperjsa
      • Apr 2004
      • 547
      • Coconut Creek, Florida
      try taking a piece of wire and touch the blinker stalk and frame. If it blinks then, it is a bad ground.
      There is also a 6 or 8 wire connector under the gas tank that the blinkers power wire go through. Check to make sure you are getting power through the connecting block.
      Owned by a pair of XS11's. An 80 Standard and a 79 Special.
      • WorkinProgress
        • Jun 2004
        • 10
        Same problem
        My left side blinkers work so I know the flasher is working and the right side blinkers both light up so I know they both have a good ground but they do not blink! WHY? Does it have something to do with the cancelation unit? Anything at this point would be a big help.
        I have 3650 cc worth of Yamahas in the garage.
        • thumperjsa
          • Apr 2004
          • 547
          Could still be a bad flasher unit. Try a cheap 2 prong one from auto parts store. If it is not flashing, it most probably because either incorect current is not getting to flasher unit causing the spring internally to flex or unit itself is bad.
          • strom
            • 1577
            • Slovenia, EU
            My bet is ground connections. As I dissasembled the rear end, rear blinkers were a royal PITA to get em to work again.
            LP
            • jimg1au
              • 102
              • sydney australia
              no power to 1 side of the flasher can
              hi
              tried to earth the blinker stalk.no luck.got test light out.1 side has power the other doesnt.will have to trace up under the tank.
              1
              have power at the switch for rhs
              2
              no power at the flasher can plug rhs
              any clues
              • thumperjsa
                • Apr 2004
                • 547
                I wold lay a bet on the connector under the tank or a broken wire.
