5-6k srumble
    Originally posted by Schming
    Probably Shaft Seals
    lol...saw that one comin' from ya Schming.
      • 9980
      Surprised Brant didn't think it was a voltage issue.
        • 5061
        Originally posted by rangerguy302
        Ok, I've got a problem with the jetting I believe. How do you Ballance the jetting so it doesn't stumble between the Jets? From idol to 3200rmp smoothe as silk, 3200-about 3800rpm stumbles, 3800-about 5200 smoth as silk, 5200rmp- about5800 stumbles, 5800+rpm rocket ship. Any advice is good advice, thanks for reading
        OK, I did some work on my 1978 Model E. I removed pods and went back to the stock airbox with a K&N filter. It has a Jardine 4 into 1 header, and testing was done at 8500 feet elevation. I don't think it matters if you have the 78-79 series or the 80-81 series as far as finding stuttering in the range. Your mains, float heights, and pilot jets may differ, but the analyses would be similar. I started with 130s because that is where it ran good before...
        Removed K&N pods, installed stock airbox with K&N. Used external
        breather filter that was used for pods.
        Set floats at 1.005, 1.003, 1.010, 1.011
        45 Mic pilots, pilot screws at 1.25 turns
        Synched
        Mic 130 mains.
        Stuttered at 4000 rpms and 5000 rpms. No maximum speed tried.
        Plug insulators looked grey, but they were not new.
        Tried Mic 137.5 mains and hooked the breathers to the airbox.
        Stuttered at 5000 rpms and really bad at 7500 rpms. Had to adjust
        idle down for 1000 rpms. Plug insulators looked tan, but they were
        grey before (not new)
        Tried Mic 142.5 mains.
        Pulls hard all through the range.
        Did not test maximum speed.
        End result: 45 pilots, 142.5 mains, 1.25 turns for pilot screws, 1.007
        inch float height avg.
          • 9980
          There is NO info on the bike in your signature. Can't help if we are shooting in the dark.
            Well, no response from original thread poster as to more bike info, so who knows, maybe be got lost in Billings who knows where.
              • 9980
              Only place to get REALLY lost in Billings is in Lockwood.
                Figured you would be the one to know......gettin' close to or 'spot-on' your ole' stompin' grounds as a 'youngin'.
                  • 9980
                  Just temporary, only lived there from 1976 'till 1997.
