Sf ? ? ?
  • Sf ? ? ?
    Is this an SF or SG ?
    Serial number says it's SF.
    http://www.ebay.com/itm/1979-Yamaha-...tZSrjI&vxp=mtr
    76 XS650 C ROADSTER
    80 XS650 G Special II
    https://ibb.co/album/icbGgF
    80 XS 1100 SG
    81 XS 1100LH/SH DARKHORSE
    https://tinyurl.com/k6nzvtw
    AKA; Don'e, UD, Unca Don'e
    Which is it?
    The seat rear grab bar and tail light are not SF. The black engine color is neither SF or SG. Could possibly have other mismatched pieces.
    1981 XS1100H Venturer
    K&N Air Filter
    ACCT
    Custom Paint by Deitz
    Geezer Rectifier/Regulator
    Stebel Nautilus Horn
    EBC Front Rotors
    Limie Accent Moves On In 2015
    Mike
      Looks like it has the kick starter nub, definitely a 78 or 79 in that regard. Brake rotors are solid without slots, 78 or 79 there as well. The look of the grab handle from a 1980 or later is definitely an improvement over what 78 or 79 had though. Engine serial number could easily be '79 and correct, and painted the cases/jugs and valve cover and machined the fins. 160 mph speedo is 79 all the way, but ad states it is not the original. Or they took the serial number off of the head stamp and not the engine, I believe it is located there as well. To me that engine kinda has a cool look to it as that bike sits.
      ZRX1200
        SF's serial numbers start 3H3. Looks like a SF with later seat, grab bar and rear fender fitted. Side cover and tank emblems are correct for SF although it looks like a later side cover, prolly changed to match seat profile. I'd guess engine has been painted black at some point, as it has all the hallmarks of a pre 80 engine.
        Rob
        Rob
        XS Eleven SF
        Could this be the finest Triumph Bonneville ever built ?
        (Cycle January 1979)
          Frankenbike.
          Looks like it has either an LG or LH engine with the older alt cover too.
          SG side covers wouldn't fit an SF without being modded quit a bit.
          This bike is a little scary.
            It appears to have the kicker spline with rubber boot, which disapeered after the SF. The side covers look the wrong shape for SF covers, later covers do fit if you bend the top fixing tabs. I know this as my SF had later covers on when I first had it.
            Rob
            XS Eleven SF
              Description says it's a 79 with "updated 80 parts.
