How do I clean this passage?
  • lowprofile2000
    • May 2017
    • 22
    • Stillwater, Minn.
    this passage is clogged on my #3 carb, its the lower one in this pic, I have tried everything in my garage, left is soak for a day, still no luck. any ideas? Any special tools I can buy that will work?
    passage lowest in the pic, the tiny pressed in jet, I can get through until the passage seems to make a turn.
    thanks!
    79 SF
  • lowprofile2000
    • May 2017
    • 22
    • Stillwater, Minn.
    Just an FYI I got through it with one of these https://www.amazon.com/Carb-Cleaner-.../dp/B001DDMB2I
    Had to tweak it a bit to make the corner but worked. Might be the first positive k&l post I have seen on here in my short duration. Same day shipping sold me otherwise would have went another direction.
    79 SF
      ......and same as a torch tip cleaner set. Glad you were able to make it work.
      • HalfCentury
        • 408
        • Burlington NC
        Guitar strings. No need to order. Just walk upstairs and open a guitar case.
        82 XJ1100 - sold
        2000 ZRX1100 - sold
        2003 FJR1300 - Silver rocket
        • mharrington
          • 407
          • Holland MI
          I always have an old bicycle cable or motorcycle cable on hand. Unravel a single strand to length and snip it off. Makes for an excellent little snaking tool.
            • 5051
            A slinky "e" string from a guitar will work.
