Stumbling
  • HalfCentury
    • 408
    • Burlington NC
    Originally posted by Bonz
    If you cut off the end of the wire at the plug cap and reinsert, you have fresh wire. It's so simple. I would recommend that before buying new wires all around.
    Having never done this required watching a demo on youtube. You are correct that its the easiest thing to do in the debug process. After chopping off 1/2 to 3/4 of an inch, the wire is nice and shiny silver at the cut point. Screwed the clean end back into the cap and twisted until tight.
    Took it out for a drive and I could tell that the stumble is still there. Pulled the plug and #2 is fouled. There is also a fairly strong gas smell when pulling into my driveway. My guess is that #2 carb has something wrong that shoves too much fuel into the cylinder.
    Another item for the group to know is that I removed the YICS bolt a couple of days ago and some dark liquid poured out of the hole. The quantity was a couple of tablespoons. I cleaned out the port and reinstalled the bolt. I am going to remove the bolt again to see if the fluid in the YICS port is an ongoing problem.
    82 XJ1100 - sold
    2000 ZRX1100 - sold
    2003 FJR1300 - Silver rocket
    • HalfCentury
      • 408
      • Burlington NC
      There is raw gasoline in the YICS port. Enough to make a wet spot on a paper shop towel. I cleaned this port two days ago so the raw gasoline is new.
      The oil level was 1/2 quart low. It appears to be burning some oil.
      82 XJ1100 - sold
      2000 ZRX1100 - sold
        Sorry if this was covered already, but you might want to compare the amount of fuel from the No 2 float bowl with others.
        Although this has nothing to do with level of fuel in the bowl, I would think that if the pilot air jet or its passage was plugged, the idle circuit fuel supply would be richer. Think of sucking soda from a straw with a hole in it.
          • 2104
          Pull the Carbs
          If I may, You need to pull your carbs and clean ALL the passages and reset the float heights before the raw fuel dilutes your crankcase oil which will lead to a spun bearing.
          Also valve shim adjustment is a critical component in the tuning process, 'cause without the engine breathing at max capacity, the carbs can't be tuned to theirs.
          • HalfCentury
            • 408
            • Burlington NC
            Hello Schming
            Thanks for chiming in. The valve clearances were check, adjusted and re-checked. I have the before and after map of the shims in a notebook.
            I agree that the carbs will have to come off and be looked at. Its a shame that 3 of 4 appear to be good and one is recalcitrant. While I have the tank and carbs off, may as well re-check the valve clearances.
            Do I recall correctly that one of the regular posters had a theory that one of the 4 carbs is the "evil carb"? Was it carb #2?
            82 XJ1100 - sold
            2000 ZRX1100 - sold
              Hello Schming
              It is carb #3. While bike idling, fuel bowl levels need to be ALL identical at 3mm below bowl mounting surface.
                Hey Schming, that winking emoticon is reserved for Motoman!!!
                  Thanks Sid, but I pretty much just use it if referencing to an issue that I've already resolved a long time ago myself............in hopes it helps someone else.
                      Originally posted by BA80
                      No surprise......figured that was comin' from ya'........sooner than later.
                      • HalfCentury
                        • 408
                        • Burlington NC
                        If the collective would speculate, what should I look for with a an overly rich carb #2? I am thinking if the air jet is plugged, that could cause a rich condition. Yes? No? What else?
                        82 XJ1100 - sold
                        2000 ZRX1100 - sold
                          Schming's post #19 would be a good start.
                          • HalfCentury
                            • 408
                            • Burlington NC
                            ok. will do and report back.
                            82 XJ1100 - sold
                            2000 ZRX1100 - sold
                            • HalfCentury
                              • 408
                              • Burlington NC
                              I performed a dry compression test. 130 PSI across all four cylinders. I guess this means that a second appointment with the carbs is in my future. I much prefer a second appointment with the carbs than appointment with the piston rings or valves.
                              82 XJ1100 - sold
                              2000 ZRX1100 - sold
                                One more thing. Is your exhaust system in good shape? Strange things can happen when a baffle is shot.
