Groove in front rotors.
  • dbmb0416
    • Jun 2015
    • 128
    • Westdale Ny
    Hi guys. I'm starting to get grooves in front calipers. Looking at the pads there still good yet. There still squeaking cause I haven't put the stop squeal grease on yet. It's rolling good and stopping well. Any suggestions. I do have replacement pads if need to change. Thanks for all the help past and present.
    79 XS11SF
    Change pads! You may have a rock or bit of something that is now worked into the pads, causing the groove. If it's deep, you may need to replace the rotor.
    • donebysunday
      • Oct 2012
      • 1737
      • New Berlin, Wi.
      + 1 with Ray !
      Inspect those pads close if you find some debris poke it out of the pad and re-install, should be good.
      If you can't find what is causing this groove and remove it, get new pads !
      OH, and the anti squeal is not grease it's more like a thick resin, sprayed on like paint that gets hard but still rubbery, a little anyway. It's made to cushion the pad against the caliper cup surface. The pad metal against the cup metal is what causes SQUEAL.
      76 XS650 C ROADSTER
      80 XS650 G Special II
      https://ibb.co/album/icbGgF
      80 XS 1100 SG
      81 XS 1100LH/SH DARKHORSE
      https://tinyurl.com/k6nzvtw
      AKA; Don'e, UD, Unca Don'e
      • dbmb0416
        • Jun 2015
        • 128
        • Westdale Ny
        Will do. Not sure if anything is poking out but I'll inspect.
        79 XS11SF
