Valve way too tight. Someone please verify this is correct
  • Ctopher87
    • Jun 2016
    • 34
    • Cartersville , GA.
    Clearance for the intake valve on cylinder #1 is .0015 with a 280 shim. I read here that each shim size is equal to .002. If that's the case I should use a 265 shim to reach the high end of spec at .008 correct? This was the tightest of them all. I just want someone to verify my math is correct.
    80 SG
    • 9981
    .0015 + .006 = .0075..you should set them at the wide end of the specs because the will close up with wear.
    • Ctopher87
      • Jun 2016
      • 34
      So the 265 shim will work. That's all for now. Thanks Greg
      80 SG
