Squeaking just happened slightly....
  • ERM83
    • Apr 2016
    • 314
    • Lehigh Valley, PA
    Went to ride a half mile to the store, heard squeaking (akin to that of a car belt), but it stopped after a literal 3 seconds. Freaked me out, so I parked it. I JUST had my baby running PERFECTLY, now this!
    80' XS1100 SG "Dottie"
    79' SF carbs
    MAC 4-1
    K&N Pods
    Accel 3.0 coils
    Tarozzi fork brace
    TC fusebox
    Picture update soon
    http://i53.photobucket.com/albums/g4...psej6wqu9l.jpg
    79' XS1100 SF (parts, will be reborn)
    http://i53.photobucket.com/albums/g4...snfgpozqn.jpeg
    Ouch....
    Did the noise seem to match engine RPM or road speed?
    • donebysunday
      • Oct 2012
      • 1737
      • New Berlin, Wi.
      Could just be a little brake dust or a slight sticking of one of the brake calipers ?
      76 XS650 C ROADSTER
      80 XS650 G Special II
      https://ibb.co/album/icbGgF
      80 XS 1100 SG
      81 XS 1100LH/SH DARKHORSE
      https://tinyurl.com/k6nzvtw
      AKA; Don'e, UD, Unca Don'e
      • ERM83
        • Apr 2016
        • 314
        • Lehigh Valley, PA
        I'm gonna check the front calipers...it VERY WELL could've been a bit of brake dust / something with those, because my brother and I have been riding A LOT lately.
        It happened when I took off from my parking space...I let the clutch out, started to go, and heard the squeaking. It only lasted for about 2 seconds, but here's the thing: it DEFINITELY coincided (sound-wise) with rpms. This worries the hell out of me.
        79' SF carbs
        MAC 4-1
        K&N Pods
        Accel 3.0 coils
        Tarozzi fork brace
        TC fusebox
        Picture update soon
          • 8891
          Could be the speedometer cable or speedometer itself.
          • donebysunday
            • Oct 2012
            • 1737
            • New Berlin, Wi.
            If RPM causes the noise to change forget checking brakes and bearings as these would be speed related not RPM related .
            Tach and engine would be culprit ?
            76 XS650 C ROADSTER
            80 XS 1100 SG
              The tach's just a galvanometer, there's no spin to it.
              The speedometer or cable would howl like Phil suggested but unless it was misheard, that wouldn't follow engine RPM.
              Maybe the cam chain adjuster slipped? If the engine doesn't jump time and eat the valves, the chain'll make a racket that sounds like the engine's screaming.
                • 2138
                I was going to mention speedometer/cable, yesterday, but I deleted my post because it seemed like uneducated guessing.
                Now that I see someone else suggested it, I should mention my speedometer went bad last year and it made a whirring noise that quickly developed into a squeal.
                It would be RPM-related if you didn't switch gears while you heard it.
                  • 2138
                  When my cam chain adjuster slipped, it was only noticeable at idle. There was a clunky knocking, clackety noise. Above idle it was not noticeable.
                  YMMV
                    My '79 made a screaming, whirring clatter at all RPMs but, yeah, it was louder at or near idle; scared me, I thought it was gonna blow up.
                    I'm trying to think of simple stuff that's not the speedometer or intrinsically fatal like a dying rotating assembly and easy to fix like a loose cam chain.
