Replacement oil filter bolt
  • dbbrian
    • May 2016
    • 596
    • Stratford, Ontario, Canada
    I picked up a new oil filter bolt from Parts n More because the head on the old one was rusty, and starting to get a bit rough around the edges.
    Once I got the old one out I compared. A bit different.
    The threaded section is shorter but I tested and seems to be enought to snug the cover up tight.
    Slight difference in the holes, new has all large size, old has large and small, but I'm thinking bigger means more flow = OK
    But I noticed inside the bolts there is a spring and ball bearing. The old one will rattle when shaken. The new one not.
    What does that thingy inside do, and should it be loose?
    Working on a picture upload
    Brian
  • dbbrian
    • May 2016
    • 596
    pics
    I give up on photobucket....here is my google drive
    Can you see them?
      • 8930
      It should not rattle, it is a bypass valve in case the filter is plugged, the oil will then be redirected and unfiltered to the engine.
      Could not access your photo.
      • dbbrian
        • May 2016
        • 596
        sharable link
        this might work
        Good to know. I guess that means my old one wasn't sending the oil throiught the filter?
        I have noticed it gets dirty real quick. Perhaps that is why.
          • 8930
          Those pics work, as long as the bolt threads in far enough you should be fine. Yes, you may have been running unfiltered oil.
          • dbbrian
            • May 2016
            • 596
            Jeepers the rusty head was the least of my worries.
            Thznks for the help.
            All back together with fresh oil, will be interesting to see the difference.
            Test drive time!
            • MPittma100
              • Aug 2011
              • 2359
              Filter bypass
              Opens also when oil is cold if you rev the engine too high. Is open when/if filter gets too dirty.
              1981 XS1100H Venturer
              K&N Air Filter
              ACCT
              Custom Paint by Deitz
              Geezer Rectifier/Regulator
              Stebel Nautilus Horn
              EBC Front Rotors
              Limie Accent Moves On In 2015
              Mike
              • dbbrian
                • May 2016
                • 596
                Geat support once again
                You guys are awesome!
                It would seem this bolt is something that should be checked and / replaced regularily but I have not seen anything about it in the service manuals about how it is supposed to function.
                Once again this website proves to be the best place to hang out.
                Thanks guys.
                Test ride went perfectly.
                  Regularly? Yeah, like every forty years or so you should replace the bolt.
                  Check it whenever you change the oil filter to make sure the ball will move with the spring and that it's not loose and rattling around.
                  I seem to remember a couple of posts about new filter bolts being defective, the ball was jammed and couldn't move or it was stuck open but I haven't seen anything recent.
                  • MPittma100
                    • Aug 2011
                    • 2359
                    Fyi
                    While you are in there, be sure that the thin flat washer and spring are under the filter. The washer sometimes preforms a magical disappearing act.
                    Thanks guys.
                    K&N Air Filter
                    ACCT
                    EBC Front Rotors
                    Mike
                    • dbbrian
                      • May 2016
                      • 596
                      The spring? check....the washer?....dang, ran out to the garbage to see if stuck to the old filter, no. Might be in the pan of old oil so I will have to decant it carefully. However I was pretty carefull to hold it all together when taken apart.
                      Thanks for the tip.
                      By the way, the oil went black within 40 km. Is this normal?
                        • 8930
                        If it is black in the sight window already I would say it may need a flush.
                        • MPittma100
                          • Aug 2011
                          • 2359
                          Spring/Washer
                          More often than not the washer does come up missing. I've seen both washer and spring missing. Have even found an additional lower metal filter ring in along with a complete filter? Springs and washers are available and both are required.
                          Thanks for the tip.
                          K&N Air Filter
                          ACCT
                          EBC Front Rotors
                          Mike
                            Hi Brian,
                            I have a spare washer..somewhere. I'll look for it.
                              Hey Brian,
                              Just to be on the safe side, want to make sure you know the correct assembly order, the bolt into the bottom of the cup, the spring goes in the bottom of the cup, then the washer on top, and then the filter on top of that. The washer keeps the spring from eating its way thru the filter, as well as keeping the filter UP next to the case and around the holes in the filter bolt closest to the threaded end.
                              IF the filter slides down because of the spring cutting/digging into the filter, then AGAIN, you will have UNFILTERED coil getting into the engine because it'll be bypassing the filter as it goes thru the exposed holes in the bolt near the threads.
                              Yep, you may want to put a 1/2 bottle of Marvel Mystery OIL into the engine and run it for a little while and then drain to help flush out a lot of the grime/gum/residue that may be ALL OVER the engine due to running unfiltered oil with that old broken filter bolt!?
