New coils and wires
  • BillyRok
    • Aug 2011
    • 421
    • Shortsville, NY.
    New coils and wires
    One of the original coils on the '81 Venturer I'm working on reads 29,000 ohms when it should be 15,000 ohms so I need to replace them. Research on the site says the green Dynatek DC1-1 3 ohm coils are the way to go. I'm wondering about what size wires to use and why and whether they come with the coils or have to be ordered extra through someplace else? And what would the expected cost be? Thanks all!
    Billy
    • 7765
    Coils and wire are ordered as needed. I would use 7mm SOLID CORE wire, as it's easier to find. The 3 Ohm coil is good, as that should be what you have. IF you have a ballast resistor, then you will bypass that.
    I would also put on new spark plug caps, as they are fairly cheap and can be ordered from any good auto parts store.
    For you coil, are you checking through the spark plug caps? If so, you can unscrew them and check each one to see if one has a bad resistor.
      No ballast resistor for ALL 81's and XJ. Also, set your meter to OHMs and check across both poles of coil....should be 3ohm. If 2.5-2.7ohm, replace them.
        • 8795
        Wires for the Dyna coils....
        https://www.z1enterprises.com/dyna-i...ore-black.html
        • BillyRok
          • Aug 2011
          • 421
          • Shortsville, NY.
          Thanks for the replies. The '81 and '82 models used the same coils according to Boats.net, and the '78 - '80 used the same coils. Here is the page from the '82 XJ service manual (for those who maybe have never seen this) showing the standard values for the coils (I posted incorrect values in my first post, memory sucks ) Standard values for the '78 - '80 models are 1.5 ohms on the primary and 15,000 ohms on the secondary according to the manual on Catatonicbug's website.
          [IMG][/IMG]
          The coil for cylinders 1 and 4 read 2.7 ohms on the primary and 11,530 ohms on the secondary, both within spec. The coil for cylinders 2 and 3 read 2.6 ohms on the primary. The reading on the secondary however starts out around 140,000 ohms and then continues to climb for several seconds until it tops out at around 180,000 ohms...way above spec! Not sure why it was reading 29,000 the other day when I checked it but obviously it has issues.
          Guess I'll be ordering the Dynatek DC1-1 green 3 ohm coils with 7mm solid core wires as the cure. Oh, I also checked all 4 spark plug boots and all read about 4.9 ohms of resistance.
          Thanks again for the feedback.
          Billy
            BillyRoc,
            Check with some one who knows But i recall one of the colors of
            DynaTeck coils has problems after just a few months.
            I recall there is Green and Black. from my memory it was the Green that were suspect.
            I have been wrong before but would hate to see you get the wrong ones.
              • 8795
              Phil, those were the Mikes XS coils that fail, not the Dynatek ones.
              BillyRok, smart move replacing those 30+ yo coils, you won't be sorry.
                Thanks bikerPhil, There you go Billy correct information come out eventually
                That is the second time I have been wrong.......and the week has just started
                • BillyRok
                  • Aug 2011
                  • 421
                  • Shortsville, NY.
                  Good guess though...
                  Whenever I post a question, I always say to myself "Well, let's see what Phil thinks and what everybody else knows! But, to your credit Phil, your spelling and grammar are usually impeccable!
                  Billy
                    Hey BillyTok,
                    I hope you will have a running bike ready for XSSE this year and the weather co oprerates.
                      • 1910
                      Hey billy
                      not trying to change the subject... but I noticed your signature only lists your XJ. Do you still have the midnight you rode cross country?
                      • BillyRok
                        • Aug 2011
                        • 421
                        • Shortsville, NY.
                        Hey Jim - I think I'd already gotten a bit off the original topic before your post, but to answer your question, yes i still have the bike. Here it is this afternoon with my XJ and the Venturer I'm working on.
                        [IMG][/IMG]
                        Haven't ridden it since I got home with it from Idaho in Aug 2014, and only put 40 miles on the XJ during all of 2016...just haven't had any time to ride. Which begs the question why am I putting another one together!?!
                        Billy
                          • 1910
                          Billy
                          good to see you still have the bike. After the journey you took to retrieve it. I haven't ridden much myself since last October. Jerk pulled out in front of me when I was on my Harley and I had to lay it down. No major damage to the bike. At my age I still have aches and pains from it. Not going to stop me though. I am making repairs to the Harley and I still have my fully restored LG. Still having problems with my LG not wanting to crank though. I can ride it for an hour or more stop for gas and when I hit the start button... nothing. I pop it back in gear, rock the bike a couple of times back and forth and voila it cranks right up. Very strange.
                            • 7765
                            Cajun, Pull the starter motor and replace it. but go through the new one first, cleaning the armature and greasing the motor so it works correctly. The original motor MAY revive once you do that, but not a given as you may have a bad spot on the armature.
                            • BillyRok
                              • Aug 2011
                              • 421
                              • Shortsville, NY.
                              After some shopping around, this looks like the best deal. Less than $130 for coils and wires with free shipping. Wonder why seller only lists Kawasaki bikes as compatible vehicles? But these will do the job right? Thanks!
                              Billy
