rear brake shaft
  • DavePlum
    • Nov 2009
    • 71
    • Longview,Tx
    rear brake shaft
    I've looked in my service manual and searched this site but can't find info on how to remove the rear brake shaft on my 79SF. I don't see anything holding it in so is it just a matter of unhooking the spring and then removing by pushing it out towards the left side? Thanks, Dave
    • 8963
    I think that is pretty much it, push it out after removing the pedal and pay attention to spring orientation beforehand. Also unhook the pin attaching the master cylinder.
      • 9981
      They tend to get rusted up inside the tube. I've had to force more than one out. A small wheel cylinder hone (mulberry bush type) works good for cleaning out the tube. Use marine grease in there when you go back with it.
      • DavePlum
        • Nov 2009
        • 71
        • Longview,Tx
        Thanks, will likely be tackling this tonight or tomorrow.
