I went out to load up for fighter practice and smelled gas. So I look under the bike and there is the dreaded puddle. Which means there is a problem and probably gas in my oil. Track it down to carb 3. Of course, now I have to pull the whole bank. Figutre I'll go ahead and do a cleaning while I'm in there. Get the bowl off #3 but the float pin won't come out. hmmm. Work it out carefully and voila!
It appears the prior owner wasn't very good at hitting the hole. It's sitting next to a straight toothpick so you can see just how badly it's bent. At least it's an easy fix. So much for fighter practice today, the carbs are soaking right now. Guess I'll go start scrubbing parts.
