Speedometer Drive Assembly
  • BillyRok
    • Aug 2011
    • 421
    • Shortsville, NY.
    I took my speedo drive apart months ago and now can't remember exactly how it went together, can someone point me in the right direction? Here is the diagram...
    [IMG][/IMG]
    Here is what I have...
    [IMG][/IMG]
    [IMG][/IMG]
    1) I smeared grease on the 2 gears inside the drive when I had it apart but didn't really pack the whole cavity, is that sufficient?
    2) Need to apply grease on both sides of the meter clutch? What about the inside of the oil seal where it seats over the gear unit?
    3) Very hard to tell in the diagram which way the raised inner lip on the retainer faces. I have it facing away from the seal/drive and towards the meter clutch...is that correct?
    Are the meter clutch and the retainer in constant contact while turning or is there space enough in the hub so they don't touch? I don't see any evidence of wear on either so maybe the coating of grease is enough to prevent wear?
    I know, lots of questions about a simple part but I'm always curious about the how and why of things. Once somebody sets me straight, I can put the front wheel back on!
    Billy
    Billy:
    Nice to hear from you again.
    (1) Yes, any reasonable coating of grease on the gears is enough- however, I put gobs in mine.
    (2) I would completely coat the Meter Clutch and the Retainer with grease. I like to put lots of grease on the inside of the seal too. There is practically no relative motion among these parts; they all turn together with the wheel; but they do slide into a favorable relative location and the grease prevents corrosion and mitigates water intrusion.
    (3) I forget whether the raised lip of the Retainer goes inside or out, but I remember whenever I try it both ways, one way seems obviously right. Somebody will chime in.
      The dish side faces out.
      • BillyRok
        • Aug 2011
        • 421
        • Shortsville, NY.
        Thanks guys...with the wheels back on at least I can roll it around the shop again, that's progress![IMG][/IMG]
        Billy
          That's lookin' so clean!
          Looks like you are on schedule for 2017 XSSE.
