Cam Chain Question
  • LabidySabidy
    • 25
    • Dallas, TX.
    Luckily I waited before taking out the spark plugs since I'm lacking a deep socket.. Is the task of resetting cams difficult?
    Kasim
    1980 XS1100 Midnight Special "Delilah" (First Motorcycle)
    "The depth of my struggle shall determine the height of my success."
      Whew!
      You look like someone that could use a fine manual:-
      XS1100oemManual.pdf 186KB
      Resetting the timing isn't difficult, it's just tedious but not as tedious as pulling the head and replacing bent valves.
      The valves are small and bumping them with the piston while you turn the crankshaft and try to sort out the timing can bend them. Before you try turning the crankshaft, remove the timing gears and unload the timing chain, then remove the cam bearing caps and lift the cams to make sure all the valves are closed.
      And here's a link to the XS1100 Forum pictorial:-
      XS11.com Forums > Maintenance > Engine > Valve Adjustment Pictorial
        Oops
        I almost forgot the 1980/1981 Supplements from Yamaha, you'll need them too:-
        XS1100H-SH-LH_G-SG-LG_Service_Manual.pdf 36 Megabytes (not Kilobytes!)
        • LabidySabidy
          • 25
          • Dallas, TX.
          Thank you 3Phase,
          My main concern really is that the chain may be off a link or so. Do you think this job would still be necessary? I changed the cct without securing tension at the top, but has the bike on the center stand, hence my worry. I'm not entirely sure why the crank won't turn completely to the "T" mark either, but I am guessing that could be a sign of a problem. I'm sorry that my knowledge isn't as vast as many others on this page. I just don't wish to ruin the bike or perform a task I don't need to, as I may end up making it worse lol Once again thanks very much man, it's people like you that make this website great!
          Regards, Kasim
          Kasim
          • LabidySabidy
            • 25
            • Dallas, TX.
            I'm pretty certain the timing is off after further investigation. I guess I will have to correct that :/
            Kasim
              Unfortunately, Kasim, it's necessary. One link or twenty, it won't fix itself so you have to pull cams, set the timing, then check the valve clearances before you button it back up in case you bent any valves.
              • LabidySabidy
                • 25
                • Dallas, TX.
                I guess that's what I'll have to do. Thanks for all your help! These links you've shared will be of great help!
                Kasim
                  Take your time and remember this is supposed to be fun!
