I've got a leak coming from the final drive on my '80 Midnight Special that ends up throwing oil all on the left side of the rear wheel. I've put UV dye into the oil and it appears to only be coming from the inside seal by the wheel.
Question is, do I only need to replace the large seal that I can see from the wheel side of the final drive (as pictured)?
Or do I need to tear the whole thing down and replace tons of other seals (no fun)?
I don't have any other visible leaks coming from the drive line.
And finally, where do I go about getting any of these seals? Can I just order a generic seal that has the same numbers on it (70x90x10)?
Many Thanks!
Many Thanks!
