Came across this recipe of 50/50 acetone and merct/dext atf mixture as a fantastic penetrant and cleaner. Will this damage the XS11 engine if used as a cleaner?
Acetone
I have heard about people putting some acetone in the gas. I get buy the stuff made for fuel system cleaning because I don't trust acetone. That stuff dissolves some plastics. I would hate to have the valve seals and seals in the carbs get adversely affected!
Down to one 1978 E. Stock air box with K&N filter, 81H pipes and carbs, 8500 feet elevation. -
I wouldn't
Acetone will remove the engine paint and damage the starter cover if it is used to clean the outside of the engine.
Some folks have used that 50:50 mixture to loosen sticky piston rings.-Mike
Previous: '68 Motoguzzi 600cc + '79 XS750SF 22k miles +'84 Honda V65Comment
I have an all metal oil can that I keep the 50/50mix in. It DOES work better than my PB-Blaster, or anything else I've tried on rusty things. And living less than a mile from the Pacific, I KNOW about rust....Ray Matteis
2H9 Mod, Truck-Lite LED Headlight, TECHNA-FIT S/S Brake Lines, Rear Air Shocks, TKAT Fork Brace, Dyna DC-I Coils, TC Fuse Block, Barnett HD Clutch Springs, Superbike Handlebars, V-Star 650 ACCT, NGK Irridium Plugs, OEM Exhaust. CNC-Cut 2nd Gear Dogs; Ported/Milled Head; Modded Airbox: 8x8 Wix Panel Filter; #137.5 Main Jet, Viper Yellow Paint, Michelin Pilot Activ F/R, Interstate AGM Battery, 14MM MC, Maier Fairing, Cree LED Fog Lights.Comment
Goo Gone
I've had great luck with " Goo Gone" and a scotch bright pad.mack
79 XS 1100 SF Special
HERMES
original owner
81 XS 1100 LH MNS
SPICA
78 XS 11E
IOTA
https://youtu.be/wB5Jfbp6SUc
https://youtu.be/RaI3WYHSuWA
Frankford, Ont, Canada
613-398-6186Comment
Works great Skids, if you can get the CRC brand red/white can, which we still can here in Colo. Problem is, that particular one has been banned from a large majority of states..... due to EPA regs. Most folks have to settle for the CRC green/white can....bummer, may as well urinate on parts needing cleaning
81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.Comment
BTW, would seriously consider changing that 'walt disney' designed cam chain tensioner to an auto cam chain tensioner(ACCT). The Venture V-4 is no.1 choice, but many links here on site as to the 40+ odd ones that work fine also
BAMN!
'81 XS1100H "Brutus"Comment
