Acetone
  • Nubian
    • Apr 2011
    • 467
    • The Big East
    Acetone
    Came across this recipe of 50/50 acetone and merct/dext atf mixture as a fantastic penetrant and cleaner. Will this damage the XS11 engine if used as a cleaner?
    BAMN!
    '81 XS1100H "Brutus"
    I have heard about people putting some acetone in the gas. I get buy the stuff made for fuel system cleaning because I don't trust acetone. That stuff dissolves some plastics. I would hate to have the valve seals and seals in the carbs get adversely affected!
      I wouldn't
      Acetone will remove the engine paint and damage the starter cover if it is used to clean the outside of the engine.
      Some folks have used that 50:50 mixture to loosen sticky piston rings.
        I have an all metal oil can that I keep the 50/50mix in. It DOES work better than my PB-Blaster, or anything else I've tried on rusty things. And living less than a mile from the Pacific, I KNOW about rust....
        • Nubian
          • Apr 2011
          • 467
          • The Big East
          I planned on brushing it on just to clean motor as nothing else has worked. Just the front of motor. Maybe a more diluted version say 25/75?
          BTW I'm working on my 1100G , no paint on engine.
          BAMN!
            • 4015
            A clearcoat does exist on there though.
            • mack
              • 2411
              • Ontario, Canada
              Goo Gone
              I've had great luck with " Goo Gone" and a scotch bright pad.
              mack
              79 XS 1100 SF Special
              HERMES
              original owner
              81 XS 1100 LH MNS
              SPICA
              78 XS 11E
              IOTA
              https://youtu.be/wB5Jfbp6SUc
              https://youtu.be/RaI3WYHSuWA
              Frankford, Ont, Canada
              613-398-6186
                Brake clean seems pretty effective.
                  Works great Skids, if you can get the CRC brand red/white can, which we still can here in Colo. Problem is, that particular one has been banned from a large majority of states..... due to EPA regs. Most folks have to settle for the CRC green/white can....bummer, may as well urinate on parts needing cleaning.
                  • Nubian
                    • Apr 2011
                    • 467
                    • The Big East
                    Red/White CRC brakleen doing the trick
                    BAMN!
                      Great, that you still have access to the 'good stuff'.
                        BTW, would seriously consider changing that 'walt disney' designed cam chain tensioner to an auto cam chain tensioner(ACCT). The Venture V-4 is no.1 choice, but many links here on site as to the 40+ odd ones that work fine also.
                        • Nubian
                          • Apr 2011
                          • 467
                          • The Big East
                          already got it thanks
                          BAMN!
