Sleeved cylinder heads deteriorated.
  • JTP obsession
    • Jan 2017
    • 7
    • Lake Louise, Alberta, Canada
    Hey everyone,
    I'm currently replacing my piston rings and restoring the engine from there up as best as possible on my 1981 xs11.
    After removing my jugs, I noticed that the plastic sleeves on the two cylinder studs (front/inside edge of cyl. 1 and 4) were completely deteriorated. I'm not sure what the function of these are, and wondering if I can get away with putting my engine back together without the sleeves. What are the risks?
    It looks like I would need to replace the studs entirely if the sleeves are critical, but I would run a high risk of snapping the studs during removal (or not finding replacements), and I can't really afford a new crankcase...
    Thanks for the wisdom!
    J.
    81 H
    • 2138
    I know the feeling
    I have not pulled the head on either of my XS11s, but I have found the same plastic sleeves in my XS750s.
    I read the purpose was for rust prevention, but that seems hard to believe because they fit loosely.
    I don't think they are important at all. On my project, they crumbled into pieces, so I just pulled out the pieces, and wire brushed the long studs. Then I coated them with a coat of grease to make me feel better about rust. I don't know if the grease would be effective with the heat, but it made me feel better.
    • TomB
      • Aug 2006
      • 967
      • Cumbria, UK
      You can rebuild without them with no problems.
      As you say they crumble when removing the Jugs, all mine have and all rebuilt without.
      Tom
        hi Mike,
        A bit of lubrication is always good makes it easier to get it in or do I mean on
        Thanks for sharing your experience of an area I have no knowledge.
          Those stud sleeves are not needed. You can go ahead and rebuild everything without them.
          • sthomag
            • May 2009
            • 60
            I replaced them with a couple of layers of heat-shrink tubing. It's cheap and easy, and it might protect against corrosion. One stud did have a little corrosion damage.
            • JTP obsession
              • Jan 2017
              • 7
              Thanks, all this makes me feel better about getting everything buttoned up!
              Say, might anyone have an extra shim adjustment tool I could buy?
              81 H
                Funny you should ask, forum member LGNM just posted some '79F parts in the For Sale forum and a valve tool too:-
                Updated list 2/25/17- small items
                Valve shims - 10 assorted sizes with installation tool $30
