Fuse Layout?
  • cmarshall48
    • Feb 2017
    • 9
    • Tempe, AZ.
    Fuse Layout?
    I feel like this really is a dumb question, but I've searched a lot on here and on google and still haven't been able to find the answer. I bought this bike a few weeks ago after it had sat for years and have rebuilt the carbs, cleaned and coated the gas tank, and changed the plugs, and I'm about ready to attempt a start except for the fuses.
    I have a new fuse box and am ready to do the swap, but my bike came without one of the fuses, and I have been unable to find any information on what size fuses are needed and in which position they belong, so any info on that would be very helpful. Thanks! This photo shows the missing fuse.
    1980 XS 1100 Standard
    1980 XS1100 Standard
  • DavePlum
    • Nov 2009
    • 71
    • Longview,Tx
    left to right:
    Tail Light 10A
    Headlight 10A
    Turn Signals 20A
    Ignition 10A
    There's also the main 30A fuse located on left side behind side cover (unless it's been re-located)
    • cmarshall48
      • Feb 2017
      • 9
      • Tempe, AZ.
      Perfect, thank you very much!
        Hey Marshall,
        Dave gave you the info, but in case you get mixed up a little, if you look closer, you'll see that the 3rd set from the left are also a bit wider/thicker gauge wire than the others, that's the turn signals, they are designed to take more power due to the THERMAL turn signal and the amount of current they need to draw/run to work, hence the 20 amp fuse vs. all of the other circuits that are 10A.
        And was also stated, Yamaha put the MAIN on the other side in a separate holder, ALSO a glass fuse, so you'll want to either replace that holder with a single one, OR...move those wires over to the main fuse panel.
        • cmarshall48
          • Feb 2017
          • 9
          • Tempe, AZ.
          Thanks a lot guys! I got the bike running tonight but it sounds like it'll need some motor work
            • 7792
            Check valves and carb sync, then if there is no loud knock from the bottom, ride it! IF it's been sitting, the rings are probably stuck so it will use oil, and smoke, for about 500 miles.
            • speedlimit85
              • Jan 2017
              • 445
              • Gainesville, Fl.
              I may need to replace my fuse box too.
              80 G
              • speedlimit85
                • Jan 2017
                • 445
                • Gainesville, Fl.
                Last night I replaced the head lamp fuse twice. The bottom clip is loose and melted the plastic.
                80 G
                • speedlimit85
                  • Jan 2017
                  • 445
                  • Gainesville, Fl.
                  A zip tie is working...for now.
                  80 G
                    • 8861
                    Order a blade type fuse box from Topcat, he stocks them for members.
                      Hi Speedlimit85,
                      There is NO MAYBE. You need to replace the fuse box.
                      Your choices are the out dated replacement of a 1938 brilliant design
                      or update to the current more reliable blade fuse
                      TC offers an easy solution or you can source it locally....for a few $$ more.
