I am working on a bike for a friend. It came to me with the fuse block hanging off the side and the headlight apart. The starter button is broken. I was able to get it to start by bypassing the button, at first. I switched the fuse block out and mounted it and now I have no power coming back from the ignition switch it seems. The wires don't seem to correlate to the schematic in the book, I will post a pic or two of that. I have power at the three fuses on the right. No power into or out of the R/W and R/Y on the left end of the fuse block. I'm trying figure out where the power comes from going into that fuse. Can someone point me in the right direction?
BtW, manufacture date is 7/79 so I assume that it would be a 1980 model. Could be wrong though. It's either an SG or SF
Also, the yellow wire has no mate, I did read in the Electrical repair section, Steves troubleshooting thread, and it appears that this yellow wire is not used on the 80 model. Thoughts?
