FJ1100 Carb Retro
  • gene
    • Mar 2009
    • 267
    • Weston, Fla.
    FJ1100 Carb Retro
    Does anyone have the initial jetting for an FJ1100 Carb going on a 1982 XJ1100?
    I looked all over for it.
    Thanks
    Gene (Florida)
    1980 XS1100SG
    Accel Coils
    4-1 Jardine Exhaust
    • 3373
    What carbs are those? Keihin 36mm like off of the ZRX, other?
    Try this link. Read the whole thing, but see Post #6. http://www.xs11.com/forum/showthread.php?t=36885
    Maybe some help even though you have FJ carbs.
    2001 ZRX 1200
    1982 Seca 750
    1983 Nighthawk 550
    • gene
      • Mar 2009
      • 267
      • Weston, Fla.
      They are 36mm Mikuni's.
      Gene (Florida)
      1980 XS1100SG
      Accel Coils
      4-1 Jardine Exhaust
      • CJPetersen2000
        • Feb 2016
        • 34
        • Lyndon Station, WI.
        Try going on FJowners.com and talk to Randy at RPM hes the host of the forum and the fj/ xj expert...
        79 SF; 84 FJ11; 81 XS650; 15 KLR650
          Hey Gene,
          The FJ1100 is also an 1100 cc engine, just slightly higher compression ratio of 9.5:1 , and it uses 4 valves per cylinder. However, the proper Fuel/AIR ratio is still 14:1, and so I would think that the stock jetting for the carbs would be close and a good place to start. Then adjust according to plug color and response.
          The '85 FJ11 microfiche states either 110 or 120 for the mains, and 37.5 for the pilots.
          • gene
            • Mar 2009
            • 267
            • Weston, Fla.
            Thanks TopCat.
            CJ told me to get ahold of Randy at FJOwners.com. He emailed me a setup to start with.
            "Here is the setup we run with the FJ1100 carbs with ignition timing and exhaust. Also with adjustable main jet needle. If your main jet needles are stock you will want a set of these http://www.rpmracingca.com/proddetai...MainNeedleShim to richen it up a bit with the pod filters and the 117.5 may be a bit rich for no timing in it but shouldn't hurt anything."
            160 air bleed
            42.5 pilot jet
            117.5 main jet
            Needle raised 1 notch
            Pilot screws are out about 3/4 turn from flush per fingernail test.
            Robert
            So I had some new 117.5 jets sitting around and I took a little ride over to Chaparral Motorsport's today.They had the 42.5 pilot jets. I thought I was going to get a chance tomorrow to try it out, but the needle seats I have are from the XJ and they are a different size. The FJ seats are in bad shape so I went a head and ordered the rebuild kit from Chaparral.
            The adjustable needles are a little pricy. Anyone here try them?
            I will have to wait till next weekend since I'm in Florida all week.
            Gene (Florida)
            1980 XS1100SG
            Accel Coils
            4-1 Jardine Exhaust
            • gene
              • Mar 2009
              • 267
              • Weston, Fla.
              Funny thing is if I didn't like tinkering, it would be cheaper to buy a bike in mint condition.
              But what kind of fun would that be. LOL
              Gene (Florida)
              1980 XS1100SG
              Accel Coils
              4-1 Jardine Exhaust
