Power BAND
  • speedlimit85
    • Jan 2017
    • 455
    • Gainesville, Fl.
    Power BAND
    It's a great feeling when the machine meshes and takes off. My current bike is a stock 1980 XS1100 G standard. I am not sure if I got it running so well it has a power ban or if my clutch is slipping.
    80 G
    • 7836
    If the RPM's seem to go up, but you don't seem to accelerate to match, it's the clutch. Get a set of Barnett springs and you should be good to go.
      • 4015
      Yuppers. U'll get used to them.
        Hey Speed,
        The XS11 engine has strong low rpm torque, but yes, there is a power band that kicks in around 4K up to ~7.5K where folks describe the feeling like trying to pull your arms off, depending on which gear you're in when you hit and go thru it!
        But as has been stated, if you crank the throttle and the rpms rise, but you don't feel or see your speed incrementing the same, then your clutch may be slipping. Check your adjustment at the engine, as the clutch wears, the clearance reduces and can get too tight.
        • speedlimit85
          • Jan 2017
          • 455
          • Gainesville, Fl.
          Hey Speed,
          Good description. Thank you.
          My clutch was slipping. I think it is working now (adjusted and cleaned cable). Tuned it up so well now, I had not experienced the power ban on this bike before.
          Also, last year, a Yamaha dealer pinched off the vacuum advance because it's broken. I just plugged a vacuum air leak.
          80 G
            Correct clutch adj. is FIRST done at throw-out bearing assembly, which is under round cover on the clutch side of motor, with cable assembly and lever left loose. THEN adjust cable assembly.
              Hi Speedlimit85,
              Welcome to the XS madness. While you are fine tuning your clutch adjustment Check under the cover for the pivot pin of the lever and give it a drop of light oil. May as well do the brake lever too while you have the 3in1 oil can out. Preventive maintenance is a wonderful thing.
                Originally posted by maximphil
                hi speedlimit85,
                welcome to the xs madness. While you are fine tuning your clutch adjustment check under the cover for the pivot pin of the lever and give it a drop of light oil. May as well do the brake lever too while you have the 3in1 oil can out. :d preventive maintenance is a wonderful thing.
                +1!...........
                  My clutch was slipping. I think it is working now (adjusted and cleaned cable). Tuned it up so well now, I had not experienced the power band on this bike before.
                  Hey again Speed,
                  Glad you found the problem. BTW, the correct term is "BAND", have corrected the thread title and post. Enjoy!
                  • speedlimit85
                    • Jan 2017
                    • 455
                    • Gainesville, Fl.
                    Hey again Speed,
                    Yea power band. My clutch is still slipping though. I will try to fine tune the adjustment again.
                    80 G
                      • 3364
                      With respect, to say the XS has "strong low end torque" is a bit of a stretch, IMO. Back in 1980 relatively speaking, yes. Today, not even. Period tests were in agreement that it didn't have much below 3000 to 3500 rpm. I would concur. It is a 610 lb bike that isn't making 60 ft/lbs until after 5k rpm.
                      This link shows a thread with a dyno chart of the 78-79 and the 80 cammed bikes (post #36). For the 80's and above, 40 ft/lbs around 2k rpm isn't all that much, barely 55 ft/lbs at 3k rpm and dips down before getting back to 55 ft/lbs at 4K rpm and finally hits 60 ft/lbs at 5k rpm. Then is back down at/below 60 ft/lbs when 7k rpm shows up on the tach.
                      2001 ZRX 1200
                      1982 Seca 750
                      1983 Nighthawk 550
                        • 7836
                        If it's slipping again, replace the springs!!! How old are the springs in the clutch? stock, they have been compressed for 36+ years. New Barnett springs are about $30 for a set, and take about 1.5 hours to install, if you are doing it for the first time. With these old bikes, they really do solve the problem most of the time.
                        Oh, and notice, I said Barnett! Some of the other springs just don't work, I've tried a few different brands...
                          • 8937
                          speedlimit85, If you have synthetic oil in the engine, you may get clutch slip. Most of us run dino.
                          • speedlimit85
                            • Jan 2017
                            • 455
                            • Gainesville, Fl.
                            Well thanks for the welcome and reply's. Back in the day I had a "79 XS1100 bored out to 1179 with an orient express kit. It had a power band!
                            80 G
                            • speedlimit85
                              • Jan 2017
                              • 455
                              • Gainesville, Fl.
                              I do have synthetic oil. I re-adjusted the clutch as it says here in tech tips maintenance. I have said this before... I think I fixed it!
                              I took a ride and beat on it and no slip (so far).
                              80 G
