my SG started running like garbage out of nowhere...
  • ERM83
    • Apr 2016
    • 314
    • Lehigh Valley, PA
    lemme backtrack on the last reply...
    #4 is firing on cold start up. i checked the spark with an inline-spark tester, and it was all good. however, after it warms up and i hit the throttle, THEN it starts failing.
    80' XS1100 SG "Dottie"
    79' SF carbs
    MAC 4-1
    K&N Pods
    Accel 3.0 coils
    Tarozzi fork brace
    TC fusebox
    Picture update soon
    http://i53.photobucket.com/albums/g4...psej6wqu9l.jpg
    79' XS1100 SF (parts, will be reborn)
    http://i53.photobucket.com/albums/g4...snfgpozqn.jpeg
      As suggested, I suspect a faulty coil, from either an internal short or housing fracture once coil warms up a bit. Once coil is cool, even an ohm check across both poles of coil could easily show it to be okay.
        • 9980
        If the wires are long enough try the coil swap. Or, just swap the wires from 1 and 4 as you said before and see if it moves to #1.
          • 5055
          I dunno. He says it fires on startup and then fails. I think it runs on startup because of the starter jets, and then fails when the choke is released. It sounds to me like a fuel delivery problem with the pilot jet circuit. Maybe an adjustment, or maybe plugged idle jet passages.
            • 5055
            Originally posted by ERM83
            so, i did the header water spray-test...1, 2, and 3 are fine, but 4 wasn't even hot at all...i could touch the pipe without even remotely burning my hand. stops firing as soon as the engine starts to get even relatively warm..
            Eric
            The bolded text is why I said that.
              .....more likely carbs are having electrical issues....... as previously stated.
                • 9980
                Brant, a flat tire is an electrical issue in your mind. Ha ha ha ha
                  Yeppers............electrickery all leaked out for sure.
                    • 9980
                    Could be the magic smoke too.
                      Hmmmm........do got a lot of that here statewide also.
                      • ERM83
                        • Apr 2016
                        • 314
                        • Lehigh Valley, PA
                        Nope, you were all wrong....
                        THERE WAS UNICORN-CRAP/DRIED BIGFOOT-PISS CLOGGING THE IDLE CIRCUIT.
                        It was the coil...yanked the carbs, checked them/cleaned them while I was in there (why not, right??), and everything was immaculate. I was actually pretty blown away! GOTTA LOVE PRISTINE CARBS.
                        I ordered new coils on thursday...they got here in the city at 3am saturday (I TRACKED THEM LIKE A PARANOID SPOUSE), and this is how impatient I am/how much I love mah special lady: I called to see if I could pick them up from the UPS hub. Here in louisville, you can't...you can at certain stores on saturdays/sundays around the U.S., though. Gotta wait until monday during the day.
                        MONDAY IS GOING TO BE AWESOME...
                        Eric
                        79' SF carbs
                        MAC 4-1
                        K&N Pods
                        Accel 3.0 coils
                        Tarozzi fork brace
                        TC fusebox
                        Picture update soon
                          Hey Eric,
                          What coils did you order??? Accel/DynaTek? 1.5 ohm or 3.0 ohm? If you ordered hi output coils, yes you are going to enjoy them. If 3.0 ohm, then you will need to bypass the ballast resistor to send 12V all of the time to the coils, not just during starting. But, if you ordered 1.5 ohm coils, then you keep the ballast resistor in circuit. Some folks have also suggested a slightly larger plug gap with the hi output coils.
                          • ERM83
                            • Apr 2016
                            • 314
                            • Lehigh Valley, PA
                            Hey Eric,
                            Sure did get the 3 ohm, and already knew about the ballast bypass! That was actually one of the first things I researched on here when I got the SG running.
                            Also, quick update: the 1-4 coil was DEFINITELY the problem...the resistance was WAY out. I figured out how it happened...I tried to fix the plug wire for number 1 and it WAS successful, however the heat-shrink came undone, thus opening up the crimp. I think all that wet weather shorted it out. I'm actually about to put the primary wires on the new ones and figure out the mounting situation...
                            79' SF carbs
                            MAC 4-1
                            K&N Pods
                            Accel 3.0 coils
                            Tarozzi fork brace
                            TC fusebox
                            Picture update soon
