Steering Bearings Loose
    • 2122
    While replacing the speedometer on the Bagger, I checked the free play in the steering head.
    I was shocked to find it had quite a bit of free play.
    I put in new bearings earlier this year. I got it on the road in August. I ran it about 2,000 miles since then.
    It took about 3/4 to 1 full turn on the spanner nut to get it back to where it should be.
    It's hard to do the "fall-away method" with the cables attached. The FSM calls for 7-8 ft-lbs on the nut, which comes out tight for the "fall away".
    I ended up just compromising with a little less than 7-8 ft-lbs, but a bit tight for "fall-away.
    Moral: Steering bearings can settle in after assembly; even if you think the races were fully seated.
    • 9980
    Mine did the same thing. I was getting a 'clunk' when I hit the front brake, took me a while to figure out what it was.
    I think it was because that lower race is such a PITA it wasn't seated all the way.
      • 5069
      Maybe after initial installation, xs11 riders should ride up and down our gravel wash-board roads to break them in and then re-adjust the steering bearings! Haha!
        Would such a ride also include a paint job/exhaust replacement?.
        • DAVINCI
          • Jan 2011
          • 1048
          • Cedar Mountain, NC
          FWIW; for my ride, the manual says to torque the stem nut down to twice the running torque then back off and re-torque to the running spec. Supposedly to seat the new races (?). Still need to re-torque each season though.
            • 5069
            Only if you crash the bike! Never crashed mine on these dirt roads in the neighborhood. --knock on wood.
