whats normal
  • djduke7
    • Aug 2003
    • 13
    whats normal
    Well I got the old girl running and am finally ready to get it on the road........but I have one last question..........how hot is the rectifier - regulator suppose to get .............while adjusting rhe idle i touched the unit and found it rather hot .....just wanted to know if this is normal tnx
    Duke
    • 5058
    I don't believe mine get very warm when the bikes are running except for the heat from the engine.
    • Geezer
      • May 2003
      • 2985
      • Willamina, Oregon 97229
      Re: whats normal
      Duke
      If it's too hot to keep your hand on for a minute, then it's too hot.
      Geezer
      • djduke7
        • Aug 2003
        • 13
        re:
        ok if the unit is too hot to touch then what could be wrong .....i dont want to crook on the road in no mans land i went throught yhe wiring with a tester and did nt find any problems......any ideas? tnx Duke
        • Geezer
          • May 2003
          • 2985
          Re: re:
          usually the unit itself but it could also be corroded or dirty connections mostly likely between the stator and the regulator/rectifier. While you're at it, check them all and coating the conectors with dielectric grease wouldn't hurt.
          Geezer
