Why not another TIRE Thread! :)
  • speedlimit85
    • Jan 2017
    • 454
    • Gainesville, Fl.
    #46
    Does anyone get the V rated tires that are built to exceed 130 mph?
    80 G
      • 3352
      When was the last time an XS1100 went over 130 mph for a sustained period would be my question to the collective? Shinko 230 Tourmaster is rated for 149 mph. Should give you some margin over lesser tires with lesser speed ratings.
      2001 ZRX 1200
      1982 Seca 750
      1983 Nighthawk 550
        They don't.
        The softer compound for the V rated tire wears out quicker too so you go through more tires than using H rated tires with an appropriate load index.
        The 230 Tourmaster has a 4-ply rating, not four plys, but [LINK] Shinko lists it as a 4-ply tire on their web site.
        For the XS1100 the front and rear tires are only available in the V-rating with load index ratings:
        Front
        57 @ 507lb (230kg) for the 100/90-19
        Rear
        73 @ 805lb (365kg) on the 130/90-16
        74 @ 827lb (375kg) on the 130/90-17
        [LINK] Web Bike World | Motorcycle Tire Speed Ratings, Load Ratings and Tire Size Designations
        Even with the H-rated tire, I wouldn't be comfortable hitting much less cruising at 130 MPH on a two or three ply tire with over 500lbs on the front and 800lbs on the rear when you hit ludicrous-speed and go plaid.
          • 3352
          speedlimit85, what are the options for 130 mph H rated tire you are considering based on your question? From what I understand and what 3phase has shared, I don't know what brands or options you have with load ratings that fit the bike.
          3phase, The ply rating is simply to put it in terms of when they used old fashion cotton fabric to make tires. Ply rating keeps things consistent across the industry and over time. I don't think the number of plies matters as much as what the equivalent ply rating is along with load capacity in combination.
          2001 ZRX 1200
          1982 Seca 750
          1983 Nighthawk 550
          • speedlimit85
            • Jan 2017
            • 454
            • Gainesville, Fl.
            #50
            I need new tires and thanks to this thread, I thought about trying another brand since you are correct that some of my brand loyalty is outdated.
            I looked at the Conti go and the Dunlops again. Instead I will try Michelin pilot and they are V rated.
            80 G
              • 3352
              Nice! Which version of the pilot is that?
              2001 ZRX 1200
              1982 Seca 750
              1983 Nighthawk 550
                It matters. They have to print the number of plies and the type on the sidewall.
                As for equivalent construction, what would you like for your cords:
                Aramid (Kevlar)
                Fiberglass
                Nylon
                Polyester
                Rayon
                Steel
                Some example tires:
                Metzeler Lasertec Front 100/90-19 57H
                Tread Plies/Materiel: 4 Polyester
                Sidewall Plies/Material: 4 Polyester
                Metzeler Lasertec Rear 130/90-17 68V (not available in H, only V)
                Tread Plies/Material: 4 Nylon
                Sidewall Plies/Material: 3 Nylon
                Edit:
                Michelin Front Pilot Activ 100/90-19 57V
                Tread Plies/Material: 3 Polyester
                Sidewall Plies/Material: 2 Polyester
                Michelin Rear Pilot Activ 130/90-17 V68
                Tread Plies/Material: 2 Aramid/ 2 Polyester
                Bridgestone Front Battleax BT45V 100/90-19 57V
                Tread Plies/Material: 2 Polyester/1 Nylon
                Bridgestone Rear Battlax BT45V 130/90-17 68V
                Tread Plies/Material: 3 Nylon
                Continental Front Conti Ultra TKV11 100/90-19
                Tread Plies / Material: 4 Nylon
                Sidewall Plies/Material: N/A (You can bet your sweet bippy it'll be printed on the sidewall)
                Continental Rear Conti Ultra TKV12 130/90-17 68H
                Sidewall Plies/Material: N/A (again....)
                Dunlop Front D404 100/90-19 57H
                Dunlop Rear D404 130/90-17 68H
                Tread Plies/Material: 3 Polyester/1 Nylon
                Sidewall Plies/Material: 3 Polyester
                Kenda Front K657 Challenger 100/90H-19 57H
                Tread Plies/Material: 6 Nylon
                Sidewall Plies/Material: 6 Nylon
                Kenda Rear K657 Challenger 130/90-17 68H
                I don't have my old Metzeler ME88 or ME880 rear tires handy but they were a genuine 6-ply nylon tire, not 6-ply rated.
                Last edited by 3Phase; 04-02-2017, 09:14 PM. Reason: Missed Michelin Pilot Activ tires
                  • 3352
                  Is not polyester the same thing as nylon?
                  2001 ZRX 1200
                  1982 Seca 750
                  1983 Nighthawk 550
                    No. Polyester = many esters. It's a synthesized group of esters like alkyd paint is a group of esters.
                    Nylon vs. Polyester
                    • CaptonZap
                      • Jun 2010
                      • 1748
                      • Denver
                      #55
                      Nylon vs. Polyester
                      Yeah, but you can't use alkyd paint to color ester eggs with.
                      CZ
                        CZ
                        Sure you can but let your little brothers find 'em and eat 'em, especially the really tasty paints with the cool colors that use lead.
                          • 4013
                          Those Kenda look interesting. I don't think they carry them in a 17" rear though.
                          I have no tentative plan for the XS yet. Still trying to get the Triumph done.
                            Yep, the Kendas are available in a 17" H68, it'll be the next tire for my '80G and probably the 16" H67 version for my XJ too.
                            ~$60 from Dennis Kirk | Kenda Rear K657 Challenger 130/90H-17
                              • 4013
                              Nice. I got the Michelins still in plastic, waiting for mount.
                                Sounds fairly complicated........think my Venturer will just stick with its existing Conti Go's.
