1978 XS1100 Cafe Racer Build
  • XSLuigi
    • May 2013
    • 62
    • Coeur dAlene, ID
    Well I finally completed the cafe conversion on this bike I picked up over 3 years ago. She's been in various slightly modified variations since pulling off all the cruiser garb the day I brought her home. The last few months were spent doing some major upgrades, and now shes back on the road. With the exception of some minor details I want to polish and fine tune, she's officially "cafe'd out". Hopefully the purists will see my attempts to preserve the feel and spirit of the bike as originally intended by the designers and engineers of the era.
    I started with an all original '78 I procured in basic running condition from a custodian, who obtained the bike after picking it up from the original owner's widow the prior season. The bike had 11k miles on her, and I paid 1100 bucks, all signs pointed to a go as it felt fitting for the theme of 11's. It seemed to have every option available from the full Vetter fairing complete with radio and glove boxes, to the luggage rack, sissy bar, floor boards and forward controls. I stripped it all down, pulled the bars off, flipped em over and put them back on backwards, imagine a faux clubman if you will. With no lighting or plates, tucked over the tank, my feet resting ahead upon forward controls, hands gripping flipped over, spun around cruiser bars, and open title in my pocket, I took her for her first run down an old country road by my house. I proceeded to rip through the gears, blasting away at WOT all the way into fifth. I climbed through the RPM range unwavering until she started leaning out and spitting. At that moment I looked down at the speedo to see a very pleasing 135MPH reading. I let off the throttle, dropped down through all five gears while pushing vigorously into the brake levers to squeeze all three disks, rolling to a rather expedient stop. After a quick U-turn in front of a corn field, I blasted past what had to have been a pre-war constructed barn as I went through the gear set once more, promptly reaching that 135MPH mark and now familiar spit of the carb jets leaning out. I putted home at a more sane speed and pulled into the garage. With what I assume was the biggest grin I've ever worn upon my face, I stepped off this mighty steed and said to myself, yes, we shall commence with a build on this one, she is most worthy. After little deliberation I settled upon the name of Kana, a not uncommon name for Japanese girls meaning strength and power. It seemed fitting for this beastly machine that in it's hay day, once boasted the first sub twelve second quarter mile time ever achieved on a factory motorcycle.
    IMAG2635 by alicari, on Flickr
    IMAG2641 by alicari, on Flickr
    IMAG2656 by alicari, on Flickr
    IMAG2671 by alicari, on Flickr
    IMAG2672 by alicari, on Flickr
    IMAG2673 by alicari, on Flickr
    I essentially did some minor mods here and there over the next couple months, pushing the bike into a road worthy condition so that I could feel it out and determine where I wanted to go with it next. Winter hit and with it a move to a new state, both of these events caused the bike to sit in the then current state until I relocated cross country. It was at this point that I started to do the real work.
    upload by alicari, on Flickr
    IMAG3400 (1) by alicari, on Flickr
    IMG_0853 by alicari, on Flickr
    I picked up a universal leather cafe seat from Dime City Cycles. After some rough placement, I then chopped down the rear of the frame to match the new lines the seat created. Next I capped the frame rails, made seat mounts, and picked up some external reservoir rear shocks with preload adjustments to appropriately adjust the stance of the rear end. Next on the docket was a modern sportbike front end to increase handling characteristics, and lower that sky high front end. While it provided for fantastic stability, it made the cycle unnecessarily heavy to maneuver into corners. I found a complete neck forward set up from a 2003 Suzuki GSXR 600. I selected this model because it offered large diameter 45mm fork tubes with modern fully adjustable valving and preload in a conventional upright fork design that didn't look futuristic Moto GP, but rather more inline with the aesthetics of the late 70s in which the bike was originally designed. The large 12.5" drilled multi-piece dual disc brakes and Tokico four pot calipers that accompanied them didn't hurt either. Not to mention the fact that the entire assembly came in around 35 pounds lighter than the stock XS set up, her diet was well underway.
    A simple steering stem bearing conversion set from All Balls racing made the mating of the 25 year separated trees and steering neck a straightforward matter of replacing two bearing races. After mock up was completed the difference the new components made became abundantly clear. An almost 4 inch drop overall, and a tall front wheel profile reflecting that of the rear created a very balanced and race inspired line set. The greatly reduced rake and trail had my concerns about high speed stability reach their peak however. This was addressed in the form of a craigslist find, a brushed aluminum aftermarket steering damper with 7-way adjustment. A bit of fab work and it was nestled comfortably below the left side of the fuel tank. Fine tuning of the components was next as I took a grinder and sand paper to the trees. Once all casting lines, mounting tabs, and switch mounts were removed, a much cleaner, machined appearance easily shown through. Some satin black paint rounded off the pieces nicely, a theme that I would carry on across the entirety of the bike, allowing the bare aluminum finish of that monstrous inline four cylinder engine become the focal point of the bike.
    IMG_1277 by alicari, on Flickr
    IMG_4798 by alicari, on Flickr
    12973137_10106137799876741_7793918025458900711_o by alicari, on Flickr
    13123080_1181750075168994_878280930306693256_o by alicari, on Flickr
    A factory Suzuki brake master cylinder was reused to power the front stoppers. However the large plastic, remote mounted reservoir simply would not do. Some clear vinyl tubing and a stainless allen head bolt fit the bill quite nicely to fill my desire of a low profile vessel to hold the extra fluid necessary for the system. The original 1978 clutch perch and lever were also reused to stay within the bounds of this "budget bike". Unfortunately the length of the lever heavily outweighed the length of the gsxr clip-ons, so naturally out came the four inch angle grinder and cut off wheel. After chopping off the ball end and another half inch of lever, I took the remains to the bench grinder to smooth out a more approachable profile and remove the last of the chrome plating. After the rough shape was formed, sand paper, elbow grease, and time generated a smooth, brushed finish that any gloved hand would be more than pleased to grip. Rinse and repeat for the brake lever, and the Moto GP inspired shorty lever set was complete, at a cost of about three dollars mind you.
    IMG_5107 by alicari, on Flickr
    IMG_5109 by alicari, on Flickr
    IMG_5108 by alicari, on Flickr
    Continuing on with the minimalist theme, only two switches would be present with the hand controls atop the custom trees. A stainless steel micro push button would do the job for triggering the starter relay, while an identical push button would fire the entire lighting system. While I retained the factory ignition wiring, I pulled every last wire pertaining to the bikes factory lighting and auxiliary systems. The removal of the switch housings, all wiring modules, and the accompanying wiring shed another five pounds off the overall weight. All was replaced with a single modern solid state relay and a handful of wires to run the headlight and new LED strip tail/brake light. I was inspired by a film sequence in which a rider is hailed by a police officer on the highway, he then pressed a button effectively killing all lighting on his bike, including the brake light, he then darts off around a truck, hits the brakes and hops off an exit ramp, then presses the same button to turn the lighting system back on. Naturally I felt an extreme urge to recreate that, so a simple circuit was designed where the brake lever switches were integrated within the rest of the lighting, and that one micro push button. I now had stealth mode on this street rocket. The electrical was finished off by integrating a modern fuse panel, relocating the ignition switch under the air box, a sealed AGM battery, and a 12V USB port on an auxiliary circuit to keep that phone topped off on long excursions.
    IMG_4722 by alicari, on Flickr
    IMG_4825 by alicari, on Flickr
    Finally some matte white paint for the fuel tank and headlight bucket pulled forth the simple color scheme I sought after. More custom brackets, mounts, and small tweaks all across the bike help to maintain the stripped down theme. Everything that wasn't bare metal affixed the engine or the fuel tank and headlight bucket, was coated satin black to accentuate those aforementioned pieces. All maintenance items were tended to... fluids, filters, lube for axles and cables, adjustments to brakes and cable pulls and critical fasteners were torqued. Rebuilds on all four of the Mikuni 34mm carburetors was next, rejetted and synced they were mated up to a set of new carb boots with custom vacuum port deletes. A UNI high flow air filter made its home within the factory airbox, sucking cool air from underneath the seat and evenly distributing it to the three inch velocity stacks feeding each carb. The flow continues through the combustion chamber across iridium tipped NGK plugs, then out to a pair of custom 2-1 headers and straight pipes, all hugged in fiberglass exhaust wrap. A set of new Bridgestone BattleAX sport tires, 150 rear and 130 front, ground this beast of a machine making it capable of sticking to the curviest of mountain switchbacks.
    IMG_4666 by alicari, on Flickr
    IMG_4688 by alicari, on Flickr
    IMG_4689 by alicari, on Flickr
    With all the bits and pieces in place, the first test ride, and then the fine tuning, commenced. Over a period of a few days and many test rides, the carbs and idle were dialed in, all cables and lever positions adjusted to provide an intuitive feel, suspension sag and ride heights were set, then rebound and compression damping were tweaked to provide the feed back and confidence on the road a rider expects when carving canyon passes. After tuning I had this 1100cc DOHC inline four cylinder monster breathing fire to the tune of 100BHP at only 450lbs, thanks to the component upgrades and diet put forth from the angle grinder. That power to weight ratio combined with the modern suspension dynamics and improved geometry made this nearly 40 year old machine rip like a crotch rocket. A true cafe racer if I do say so myself.
    IMG_5104 by alicari, on Flickr
    IMG_5106 by alicari, on Flickr
    IMG_5105 by alicari, on Flickr
    Somehow, I was able to get everything dialed in with enough time to hit the 2016 Distinguished Gentleman's Ride in LA. Rolling down Hollywood blvd on my freshly finished cafe racer among 1,000 other vintage motorcycles, all dressed to the nines supporting a worthwhile charity, was quite the surreal experience. I can only imagine what other adventures and places this fantastic machine will take me to.
    IMG_4933 by alicari, on Flickr
    www.LICARIco.com
    https://www.instagram.com/licari.co/
    '80 XS11 Special Cafe - "il corvino" Invited to The One Moto, HandBuilt Show, Land Locked, Nowhere Moto, Spokane Moto Show
    '78 XS11 Cafe - GSXR front end, performance suspension and tires
    '78 XS11 Standard Sleeper, `85 FJ1300 carbs, kerker 4-1
    '74 DT250 Custom Tracker
    `79 SR500 Scrambler
    `78 TT500 Desert Sled
    `74 CB750 Chopper, survivor bike, preservation completed
    As a purist, I hate seeing a nice '78 going under the grinder. As a motorcycle rider, I DO like what you have done. A LOT of work, but not left in a pile of rubble as most have done.
    In the end, I LIKE it! Well done, sir.
      • 4015
      Must be the matte white paint and header wrap that got you that 108 bhp number , or maybe an extreme case of poetic license.
      Reason that bothers me, is there are members on here that have spent WAYYYYY more time and money on their bikes than you (for the benefit of forum education), and only two guys I know were able to squeeze that hp out of their engines (Aussie1100G).
      So, if you are going to b.s. the hp numbers on your bike, at-least read through the hundreds of threads as many of us have, that read attaining those numbers are not cheap, especially on a "budget" as you were.
      Btw, I think the bike looks pretty good. I liked how it was lol, but I hope it's not done, I.e. (tank emblem filled-in).
      • XJOK2PLAY
        • 2099
        • Skiatook, Ok.
        Morning, Ian...
        I believe he states 100 BHP, not 108.
        (But I agree... Even 100's a stretch.)
        I remember all the time, money, and dyno runs Maximan made on 'Zilla...
        2011 Kaw Concours 14 ABS
          Hey Guys,
          Play nice now! Remember, he started with the 78E engine, the strongest, fastest of the series. The OEM is built and tuned for OVERALL performance, not necessarily top end type. He has more free breathing exhausts, and probably also jetted/tuned the bike perhaps for more top end type power. I can only assume that he put it on a DYNO to get the output results....and we know that each dyno is different and so the results may be different....but 5 hp more than the stock 95 BHP to me isn't too much of a stretch along with the variance in dyno testing equipment??
          Luigi, I, too was a bit upset at the appearance of the bike when you started, seeing an otherwise pristine machine. However, you had the skills to perform your conversion to completion, and have a fine "distinquished" running machine that meets your needs and desires for both aesthetics and performance. And since you were on a budget, I would hope that you were able to sell those other fine takeoff components to some other Xsives that would be able to put them to good use and reimburse you to help your budget's bottom line.
          Hope you have many years of fun and enjoyment out of your new ride.
          Also...just to add to the knowledge database....folks might like to hear a little more details about the front end conversion....about the steering bearings set used so that you didn't have to do surgery on the steering shaft or frame neck to accommodate the new parts??
          • MarkD
            • Jun 2013
            • 488
            • N. Michigan
            +1 on Ray's comments. Enjoyed your writing , too.
            79 F
            1967 Suzuki X6 Hustler
            1973 Suzuki TM 125
            1979 XS1100 F
            2005 Kaw. Vulcan VN800
            1991 BMW K75
            • XSLuigi
              • May 2013
              • 62
              • Coeur dAlene, ID
              First off, I'd like to say thank you for the positive comments from everyone. That means a lot coming from a crowd of people who know these machines better than most.
              Yes, there are still a few finishing touches to wrap up. I am making some custom badges to replace the factory Yamaha emblems on the side of the tank. I am making some custom low profile side covers that better flow with the lines of the seat as well.
              I agree with you all about tearing down such a clean XS. I'm always hesitant to chance molestation of a cherry example of a rare piece of engineering history. However, keep in mind that I picked up that bike almost 4 years ago and she now has far more than the 11,000 miles that were showing on the clock when I started riding her. Also, I essentially only cut off the frame rails from behind the rear shock mount, so the bike is far from a hacked up mess. Additionally, I firmly believe that the original designers of this machine never intended for it to be a tall, stretched out cruiser clad in plastic fairing work and luggage racks with a radio and speakers hanging above the fuel tank, even though that is how it was eventually marketed. No, I truly feel that they, just like most designers, first envisioned their baby to be simple, clean, and understated. This was merely my attempt to create that with the assistance of some modern performance upgrades. I know most of you fall more into the purist category and don't necessarily agree, that's not lost on me and that's ok.
              Thank you TopCat for your clarification. Yes I stated 100BHP, only 5 horse over that of the factory configuration for this 78E engine. This is merely an estimate at this point, done mostly for simple approximation of power. I have not yet had a chance to get to a dyno to prove these numbers as its been back on the road less than a week. I will most certainly post up a dyno sheet as soon as that is done, hopefully by the end of the week. However, I would like to say that my experience building and tuning race engines, and working as an engineer for K&N, I feel that is a safe estimate. Take into consideration the open free flowing exhaust, open cell foam high flow air filter, stepping up the jets for the carbs, and hot plugs. Remember that foam filter is letting significantly more air into the carbs. The heavy jetting is letting a significantly heavier fuel and air mixture into the combustion chamber. Those hot plugs are ensuring the entirety of that heavy mixture is being ignited. That header wrap keeps EGTs up, allowing the exhaust gas molecules to maintain velocity, which in turn promotes everything to more rapidly exit the system, which we all know results in an increase in power. So the 5.2% increase I estimated is not out of the question.
              Also not to worry about all those very rare accessory components that I stripped. Not a single one was damaged, and I sold the entire kit to a fellow member on this site who fitted it all to his burgundy painted XS.
              As far as the GSXR front end conversion, I found a very helpful resource at http://www.allballsracing.com/index.php/forkconversion
              Simply plug in you year make and model of frame, then the same for the front end you are planning to use, and All Balls Racing spits out a list off all their bearings that match the appropriate steering neck ID and new steering stem OD. Add them to your cart and when they show up at your door you just have to replace a pair of bearing races and maybe add a spacer to the new steering stem before installing the new bearing. I put just under 400 miles on this set up and it has functioned fantastically.
              Again, I want to say thank you for all your input, its greatly appreciated, and I will definitely keep this thread updated with changes as they come.
              Also, MarkD, very happy to hear you enjoyed reading the story!
              www.LICARIco.com
              `79 SR500 Scrambler
                Hey again Luigi,
                Thankyou for your clarification of your knowledge and experience base, Motoman has similar credentials.
                Okay, you mention "hot plugs"=Iridium tipped, however, they aren't necessarily that hot. You didn't say you changed anything else about the ignition system so I can only assume that you're still running the OEM coils complete with the OEM ballast resistor. As you've rewired the bike down to essential components, I would hope you realized that you have 35 year old coils that are only ~15KV output at best, and that's going to be mostly during starting mode when the TCI routes full 12V power to the coils for easier starting, but once running, routes power through the Ballast Resistor which effectively drops the voltage down to about 9 V, which will also drop the total KV output as well. This action was designed for these 1.5 ohm coils to prevent burning them up. Hopefully you kept the BR in the wiring circuit with the TCI after your rewire work? IF you got rid of the BR/Bypassed it, then yes the coils will be seeing 12V all the time, but that will eventually burn them up, if they get to burn that long, because the TCI needs to see a total of 3 ohms on the trigger side of the coil circuit....1.5 from the coils and 1.5 from the ballast resistor. If the BR is removed and you are still running the 1.5 ohm coils, then too much current will be drawn from the TCI and it will burn up the circuits and fry your TCI!
                A suggestion to get much more FIRE from those hot plugs is to go a bit beyond your budget and install either Accel or DynaTek 3.0 ohm dual tower high output coils that deliver 35+KV and are happy to run on 12 volts all the time, and have 3 ohms, so you CAN bypass the ballast resistor with impunity. Just some more info to wring out more power from your setup before you put it on the dyno!
                And thankyou for that steering bearings conversion link...didn't know they had such a thing!
                  XSLuigi, with your qualifications, nice job with making that 78dresser into that style of bike!(add the T-Kat fork brace to reduce bushing wear and definitely improves handling).
                  T.C., thanks for the compliment/comment!
                    • 6765
                    I have to agree with Ray...
                    2005 Honda SilverWing 600
                    2018 Honda PC-Xpress 150
