anyone use accel coils??
  • ERM83
    • Apr 2016
    • 314
    • Lehigh Valley, PA
    I have the wires already...just wanted to spruce up the SG, and see if anyone had opinions. Good?? Bad?? Ehhh?? OH...the wire crimps that come with these are TERRIBLE...that's a huge reason that i wanted to just get the coils. i had to do the cut/crimp method, because my coil for 1-4 has been mounted strangely...I need to get a pretty deep socket to get them off. being that the wires are built in, i think new coils would be the better option....
    80' XS1100 SG "Dottie"
    79' SF carbs
    MAC 4-1
    K&N Pods
    Accel 3.0 coils
    Tarozzi fork brace
    TC fusebox
    Picture update soon
    http://i53.photobucket.com/albums/g4...psej6wqu9l.jpg
    79' XS1100 SF (parts, will be reborn)
    http://i53.photobucket.com/albums/g4...snfgpozqn.jpeg
  • wingnut
    • 695
    • NC
    I have them on my 81. Put them on about a year ago and like the smoother idle and it is smother thru the power band. Mounting was done with L brackets and it is tight on a special. The Accell wire clamps are problematic. They could have done much better there. I'm running the 8mm wires and boots that the kit came with although I have built non resistor 6mm copper core wires and will install them at the first sign the fiber wires are giving up. I did clamp them using aviation adel clamps to keep them from failing due to flopping around in the wind.
    wingnut
    81 SH (Daily Ride)
    81 XS 400
    Thomas Jefferson
      I have Accel coils on my '80G. Before I tore it down this time it had, like, 35 or 40K on them with no problem but those sucky wires.
      • red bandit
        • 950
        • central michigan
        I have Accel coils. I bought them used without wires. I bought wires at the auto parts. I cross drilled them IIRC and mounted them in the OEM place. Not much room there. It's been a few years, no problems.
        79 F full cruiser, stainless brake lines, spade fuses, Accel coils, modded air box w/larger velocity stacks, 750 FD.
        79 SF parts bike.
