Strange
  • donebysunday
    • Oct 2012
    • 1737
    • New Berlin, Wi.
    Strange
    noise at speed on my XJ 1100. Sounds like nails on a chalkboard only much deeper. Only happens when I reach 30 mph. or more (not consistent) and stops once speed slows to less than 25 mph.
    I think I remember this sound (hard to say) on my 64 GTO when the starter would not disengage.
    Any thoughts kind sirs ?
    Thanks, Don
    76 XS650 C ROADSTER
    80 XS650 G Special II
    https://ibb.co/album/icbGgF
    80 XS 1100 SG
    81 XS 1100LH/SH DARKHORSE
    https://tinyurl.com/k6nzvtw
    AKA; Don'e, UD, Unca Don'e
    Thanks, Don
    Hmmm.......my starter actually fell out of my 64Goat......for reals...as was the 70'Judge motor I installed. front or rear wheel bearings?..........alt.assembly?...........speedo cable spinning in housing?...............just some thoughts.
      Don, I don't supposed you could localize the sound a bit to the engine or running gear?
      Like, does it go away if you pull in the clutch and let the RPMs drop like a stuck starter would do or does it keep going while the bike's rolling faster than 30 which is just about every single thing in the wheels and the running gear past the clutch and primary shaft?
      • donebysunday
        • Oct 2012
        • 1737
        • New Berlin, Wi.
        Strange noise
        I'll try this, pulling in the clutch letting the engine slow while keeping speed up seems like a good way to narrow it down !
        Thanks
        76 XS650 C ROADSTER
        80 XS 1100 SG
        • donebysunday
          • Oct 2012
          • 1737
          • New Berlin, Wi.
          Strange noise
          I talked to the guy I bought it from, he says he heard it on occasion, thought it was speedo cable he says. I'll post results.
          My starter was to tight (must have been really close to the flywheel) one thin shim (at the time did not know about these) and was fine. I'd say you had more clearance than needed ?
          64 with 70 Judge engine, I like ! 455 how many and or how big was the turbo ? ? ?
          Thank You
          76 XS650 C ROADSTER
          80 XS 1100 SG
          • donebysunday
            • Oct 2012
            • 1737
            • New Berlin, Wi.
            Strange
            noise only sounded itself once on a ride I just got back from (rained everyday since I posted this).
            The noise started and though I pulled the clutch and let the engine slow the noise was there until speed dropped below 30mph.
            This means the drive line or maybe the speedo are culprit ?
            76 XS650 C ROADSTER
            80 XS 1100 SG
            • GLoweVA
              • Jun 2011
              • 1957
              • Virginia Beach, VA.
              I had a sound like that once, just before my speedo grenaded. Basically the 35year old gears ground up inside and then i had no output of speed.
              80G (Green paint(PO idea))
              The Green Monster
              Got him in '04.
              bald tire & borrowing parts
              Scarlet
              Got her in '11
              Ready for the twisties!
              81H (previously CPMaynard's)
              Hugo
              Cold weather ride
                That's what I was thinking too. Sorry, I've been out riding today and shopping for a new motorcycle cover, then stopped for dinner. These little XJs are fun!
                So anyway it could be the speedometer, cable, or the drive down on the front wheel. Cable will usually kind of do a wind up/wind down rattley howl, speedometer or the drive will mostly just hoot, then break.
                Ah, dinner's served.
                • soccer4m
                  • 694
                  unscrew the cable
                  Try unscrewing the speedo cable at the bottom or the top going into the speedo and if it stops sqeeling it either the cable or your speedo. THen pull out the cable and lube up the cable with some grease and if it still squeels its probably the speedo unit going into destruct mode. As a last resort, take apart the speedo,,,pain in the axxs,,,,,and lube it up with some good silicone grease and if that is too much work,,,I just drilled a big hole in the back and shot silicone grease all over the gears and it worked fine...........keep us informed,,,,Mike in Sun Diego
                  mike
                  1982 xj1100 maxim
                  1981 venture bagger
                  1999 Kawi Nomad 1500 greenie
                  1959 wife
                    .....actually a 35+yr. old housing spinning a likely 35+yr. old cable. No lube and resistace soon will find the weak piont.
                    • donebysunday
                      • Oct 2012
                      • 1737
                      • New Berlin, Wi.
                      Strange
                      noise stopped when cable disconnected, so glad it seems to be speedo or cable not gears !
                      I can't figure how it could be so loud, Olinrj (Bob) said he could hear it on our short ride.
                      Now to lube and test, (looks like rain again).
                      I'll post next results.
                      Thanks all !!!!! Don
                      76 XS650 C ROADSTER
                      80 XS 1100 SG
                        Speedometer drive --> cable --> speedometer --> speedometer housing bell
                        My original speedometer on the '80G screamed once, then grenaded. It is truly amazing how well sound can be mechanically transmitted and amplified by what amounts to a Gramophone made out of a mechanic's stethoscope connected to a megaphone:-
                        His Master's Voice
                        You may be able to grease the speedometer without taking it apart.
                        Wear eye protection.
                        Trust me.
                        Wrap a small piece of cloth or plastic tightly around the threaded speedometer input and the red straw on a can of lithium grease. That will seal the input and help convince the grease to go up under pressure and around the input cable drive adapter and onto the speedometer worm gear instead of shooting back out of the hole into your remaining eye. Don't overdo it or you'll fog the glass and faceplate with lithium grease, then you will have to take it apart.
                        The speedometer drive at the front wheel is a little more complex if you want to clean it and grease it but oil or a couple of shots of lithium grease may work for a short amount of time and hopefully keep it from seizing and stripping.
                        Finally, pull the inner speedometer drive cable out of the cable sheath to grease the cable and see if it's shredding, then thread it back into the sheath. Gently twist the cable until you feel it engage and drop into the speedometer drive down at the front wheel, then put the cable into the speedometer input and cinch up the sheath.
                        I dug up the pictures of the speedometer drive from when I put the SS brakes on my '80G and did a lot of other work while I was at it. I've made a separate post so it won't get buried:-
                        XS1100 Standard Speedometer Drive Maintenence
                          My speedo screamed and then grenaded too. I'm on my third one as far as I know.
                          • donebysunday
                            • Oct 2012
                            • 1737
                            • New Berlin, Wi.
                            Strange
                            noise will not show it's ugly head since I lubed the cable
                            Now why can't I find my post about anyone using needle bearings in the brake and clutch levers ?
                            Thanks, Done
                            76 XS650 C ROADSTER
                            80 XS 1100 SG
                              Thanks, Done
                              Go to the User CP field on the upper left of the page. Click on it and when it opens, click the Show All Subscribed Threads button and it should show up.
