Hi all:
As per thread search recommendations, I checked the connector for the stator coil. I ashamed to say it was toast. So I replaced the connector. I tested the voltage output @ 2000 RPM =14.57 Volts. Took the bike for a couple of test runs. The time it took for the fuse to blow was definitely seemed longer but; much to my dismay right as I was duck walking the bike into the garage, XS11 Black out.
I checked my work and found one of my crimps on the stator wires was not good. (I'm hoping this was the cause.)
Back to the thread search:
I read a member had a problem with a grounded stator. So i checked stator and field coil. No conductivity to ground.
Stator across all three .5 OHMS Factory spec. is .4 plus minus 10 %
could this be the problem?
Field coil is the 3.5 Ohms.
Your thoughts please.
Thanks in advance.
Thanks in advance.
(Sold back to Maximan)
