Back to working on bike after 4 yr break
Mac
pipes, I've the same exhaust on my LH/SH. Love the sound, quiet until you get on it then it roars.76 XS650 C ROADSTER
80 XS650 G Special II
https://ibb.co/album/icbGgF
80 XS 1100 SG
81 XS 1100LH/SH DARKHORSE
https://tinyurl.com/k6nzvtw
AKA; Don'e, UD, Unca Don'e
Did you remember to remove the ballast resistor when you installed the dynas? You'll also want to gap your plugs at about .035" to accommodate the increased voltage.I think I have a loose screw behind the handlebars.
Originally posted by 1strauss View PostI was unsure what kind of exhaust was on the bike, you think its a mac system?I think I have a loose screw behind the handlebars.
My plugs, caps, and wires came in and I got them installed. I made up a temporary fuel tank, hooked up the battery and decided I better check spark before I put fuel in the carbs...Well, no spark on 2 and 3...1 and 4 look good with the new dyna coil! I believe the ignition unit is bad, here is what I have done.
Swapped coils-same
Swapped terminals at 4way plug at unit using jumpers I made to check the pick-up circuits-still no spark on 2-3.
I have eliminated the coils and pick up, checked orange and gray wires from unit to coils with ohm meter-good.
Anything I have missed?79 SF
1/4 and 2/3 run off the same coil, so if you're dropping 2/3 it's most likely the pickup coil wires, or the coil itself. Are you running the original coils?I think I have a loose screw behind the handlebars.
Check your primary and secondary resistances at the coils, and see what you get.I think I have a loose screw behind the handlebars.
Did you do the resistance tests on the four prong connector at the TCI?I think I have a loose screw behind the handlebars.
Did you do the voltage tests on your TCI?I think I have a loose screw behind the handlebars.
