Carb trouble
  • MPittma100
    • Aug 2011
    • 2359
    Carbs
    Make sure that the carb diaphragms have no holes/splits/cracks in the rubber. Also make sure that they are tight on the slide, If any of this is present, you will need to replace.
    1981 XS1100H Venturer
    K&N Air Filter
    ACCT
    Custom Paint by Deitz
    Geezer Rectifier/Regulator
    Stebel Nautilus Horn
    EBC Front Rotors
    Limie Accent Moves On In 2015
    Mike
      Originally posted by Cowsert_C
      They are K&N pods, but will be in the trash soon enough. I have a breadbox airbox on the way to replace them. I have been doing all the diagnostic tests without them on.
      Bummer..........have been down Columbus way many times visiting inlaws and such. Could of been of serious help and brought a stock airbox to donate to your cause as we drove down there two summers ago and didn't fly..
      • Cowsert_C
        • Mar 2016
        • 18
        • Columbus, GA.
        Figured it out
        Hey guys, thanks to everyone and a wide range of things done to the bike, I was able to get all four cylinders firing again.
        Still have high Rpms, but that's the least of the problems now.
        1981 XS1100SH - First time owner.
        • donebysunday
          • Oct 2012
          • 1737
          • New Berlin, Wi.
          K&Ns
          Don't throw those K&Ns away, they are some of the good pods. Worth at least $40 used and $100 new. They and UNI pods are the ones that are known to work well.
          If you really don't want them let me or any of us make an offer.
          76 XS650 C ROADSTER
          80 XS650 G Special II
          https://ibb.co/album/icbGgF
          80 XS 1100 SG
          81 XS 1100LH/SH DARKHORSE
          https://tinyurl.com/k6nzvtw
          AKA; Don'e, UD, Unca Don'e
          • GLoweVA
            • Jun 2011
            • 1957
            • Virginia Beach, VA.
            The high rpms may be a sync issue. i.e. one or more carbs are delivering a little bit more fuel than the others because those have a higher vacuum. Check the maintenance section of the forum for the budget sync rig with the pvc pipe and aquarium air 4way valve. Minimal $ and works fine.
            80G (Green paint(PO idea))
            The Green Monster
            Got him in '04.
            bald tire & borrowing parts
            Scarlet
            Got her in '11
            Ready for the twisties!
            81H (previously CPMaynard's)
            Hugo
            Cold weather ride
              • 5043
              Although you might find a vacuum leak through the synching process, higher rpms issues will not be resolved with tweeking the throttle plates at low rpms. Synching is not the answer...
              • GLoweVA
                • Jun 2011
                • 1957
                I meant at idle, if it's revving high then it may be a sync.
                But you're right, a vac leak would cause it too.
                The Green Monster
                Got him in '04.
                Scarlet
                Got her in '11
                Hugo
                Cold weather ride
                  • 1224
                  • Peachtree City, Georgia.
                  Carb Sync?
                  Cole,
                  I may have missed it somewhere in this thread but have you attempted to synchronize these carbs? I have a pretty nice snyc. gauge set here in Peachtree City you are welcome to borrow for a short period of time....It's a little drive for you up from Columbus but not too awful bad. I would be better to do this once the air box is installed but the sync set could show you if you are really badly out of adjustment.
                  KURT
