The 5k jump
  • rangerguy302
    • May 2014
    • 125
    • Billings Montana
    The 5k jump
    Recently my old battle ship started jumping g and bogging at about 5000rpm. I'm running 145 mains jets, Mac 4-2 exhaust, and pod air filters. I checked the pick up wires and thier solid and just replaced the fuel filters and lines. Any ideas guys? Speed limit is 80 here in Montana and that's too close for me to think I'm running lean. Love this old bike and do NOT want to F it up. Any advice is good advice. Thanks again guys!
    79 XS11 F
    • 9981
    Pull the mufflers off that Mac system and see if that makes it better. I had to build some custom baffles for mine to get it to work right.
    • hamjam
      • 1003
      • Toronto ontario Canada
      what changed ?
      Seamus Ó hUrmholtaigh
      Niimi Moozhwaagan
      and SOXS
      2008 Nomad "Deja Buick'
        • 9981
        Originally posted by hamjam
        what changed ?
        That's what I said after 6 years of mine running fine. I always had a little stumble at WOT about 5K but about a year and a half ago things started getting way worse. I couldn't even use full throttle and it would start bogging and bucking for no apparent reason.
        Turned out the Mac turnout baffles all of a sudden were too restrictive. Still haven't figured that out. The only thing that makes a lick of sense is the gasoline formula changed.
        I dunno.
        Ended up buying a Mac flare tip system with removable baffles and building my own straight through baffle. Runs GREAT now.
        My threads on the subject.....
          • 8893
          Try the fuel taps set on prime, maybe a crack in a vac hose not letting the tap valve to stay fully open, causing fuel starvation. JAT
          • rangerguy302
            • May 2014
            • 125
            • Billings Montana
            Good idea
            Good thought bikerphil. Thanks to that I have now discovered that my petcocks are frozen open....THEY PUKE FUEL.....no leaks though,lol. No change still bucks n jumps. A while ago I was rocked by the impulse to "rinse" the muffler's out, heard that the baffles plug up so I'm going to look at those. For now I'll take the back roads and keep her off the interstate.
            79 XS11 F
              • 9981
              Tried that, didn't work......
              • werdna80
                • Dec 2015
                • 54
                • Grayling, MI
                When was the last time you checked/adjusted your cam chain tensioner? I had a similar problem on my G, found out the exhaust cam had jumped 2 teeth, couldn't get the rpms last 5500
                Just my two cents...
                80 G
                • hamjam
                  • 1003
                  so no kinks in te fuel lines and they are clean seafoamed a tank of gas ?
                  new plugs and a chop test at 5000 rpm shows ?? did you try 1/2 choke? at 5000 rpm make a difference ? yeah yeah ..but its easier to type than mixture enriching lever
                  change the needles to richer for a run see if that helps or maybe you need summer air in the blinker fluid reservoir :-D
                  Niimi Moozhwaagan
                  and SOXS
