Ignition woes
+ More Options
Posts
  • Hepcat
    • Apr 2004
    • 190
    • Captain Cook, HI
    Ignition woes
    Would one of you wonderful fellow XJ owners go out and tell me if the engine will turn over when the kill switch is set to off. I suspect the engine will turn over...but the TCI is disabled so you will have no spark. I'm away from my bike at the moment and can't do it myself.
    Thanks!
    __________________________
    Jon Groelz
    '82 XJ1100J-John
    '78 XS1100E-Name Forthcoming (It's a Girl!)
  • foxjohnc
    • Sep 2003
    • 90
    Nope, mine wont.
    • bkr
      • Nov 2002
      • 157
      • Fredericton N.B Canada
      Kill Switch
      No mine won't either bkr
      • rover
        • Jan 2004
        • 765
        • central WI (715)
        XS's won't either
        79 F (Blueballs)
        79 SF (Redbutt)
        81 LH (organ donor)
        76 CB 750 (gone to MC heaven)
        rover has spoken
        • pathfinder
          XStremely XSive(Deceased)
          • Apr 2004
          • 483
          • Houston, TX
          Run Stop
          Nope XS1100E either. No fire at all with kill switch in stop position. Run, Stop means just that.
          78XS11E
          • Hepcat
            • Apr 2004
            • 190
            • Captain Cook, HI
            Thanks guys,
            That answers that question for me. I was hoping it would be something other than the TCI. I guess not.
            Jon Groelz
            '82 XJ1100J-John
            • randy
              • Dec 2003
              • 4521
              Jon,
              Could still be something other than the TCI:
              -Weak Battery
              -Corroded connector, (especially the one at the solenoid that boosts the coils during cranking).
              - Bad Ballast resistor.
              -Fuse?
              HTH
              Randy.
              P.S. If you want the TCI fixed, PM me.
