New Petcocks?
    • 6764
    New Petcocks?
    I saw this somewhere else but i cant find it now...looking for alternative petcocks...universal? Who makes them and how much? Mine are FUBAR-ed and the internal springs are AWOL...so if I had the springs these petcocks might be rebuilt..pisses me off that i spent 60 bucks for rebuild kits and then it still cant get done...a simple effing petcock rebuild J F C..(use your imagination)
    2005 Honda SilverWing 600
    2018 Honda PC-Xpress 150
    Hmmm........imagination says removal of the outer chrome covers FIRST could of resolved that expense.
      • 6764
      no...you're way off...
        can't be far, once cover is off 'should of been there' spring is behind vacuum diaphragm. A know working fuel shut-off to put inline on each hose to carbs would be Pingle........again, some more cash is needed......
          • 6764
          were talking about petcocks not carbs... PM'd ya...
            Yup.....'each hose to carb' bout covered it.
            • Buckmaster79
              • Nov 2011
              • 98
              • Treynor Iowa
              Pingles
              I put two on my tank and love them right side to left two carbs
              left side to right two carbs. but no reserve I use trip o meter and fuel light
              i'm looking for fuel at 80 miles.
              79 SF
                • 3953
                Hey Ben- I believe it was Mack that posted about the new petcocks he's using on his bike. There is an adapter plate that must be used with it.
                  • 6764
                  Thanks guys..i found that thread Ian...Pingles look nice but out of the budget at this time....for now the these petcocks are being rebuilt and the vacuum is being restored as well...new springs for the diaphram are located but not yet procured...so this is still a WIP
                  • Rickrod3
                    • Jun 2009
                    • 721
                    • Oakland, New Jersey
                    Pingels are pricey but:
                    I've been through the petcocks at least three times problem always seems to come back. I gave up on the stock configuration and bit the bullet for the Pingels. Mine have On Off and reserve. The oil contamination and the leaking gas while the bike was on a tender (Gas and electricity) Kinda dictated too me that if I'm keeping this bike I gotta resolve this once and for all.
                    Good Luck just my .02 cents
                    Rick
                    650SF
                    XS1100SG Project bike
                    • ViperRon
                      • Feb 2011
                      • 1062
                      • Woodstock, VA
                      If money is short and times are hard you can turn the petcocks to (prime) run all the time and get the little plastic shut shutoff valves for lawn mowers. They will cut gas off for sure. With the petcocks in prime gas should be available from tank anytime valve is on.
                      Cheapest permanent fix I know of.
                      Now if you want to still rant about what you don't have, or can't get, we are here to pick on you.
                      Rodan
                      1980 G Silverbird
                      1198 Overbore kit
                      Grizzly 660 ACCT
                      Barnett Clutch Springs
                      R1 Clutch Fiber Plates
                      122.5 Main Jets
                      ACCT Mod
                      Mac 4-2 Flare Tips
                      Antivibe Bar ends
                      Rear trunk add-on
                        • 2096
                        Rebuild Link
                        Hi Ben,
                        I no way am I suggesting you need a tutorial to rebuild your bikes petcocks but this following thread, for anyone that is contemplating the stockers quality, when followed to a "T" will restore the factory quality to not only the petcocks but to the Octy valve also.
                        http://xjbikes.com/forums/threads/re...-w-pics.25058/
                        GL HTH
                          • 6764
                          Thanks John...
                          • ViperRon
                            • Feb 2011
                            • 1062
                            • Woodstock, VA
                            Been that is a very good write up and I agree with nearly all except if you have a proper stone with right angle you can still polish out the seat that it said is toast. If you do not have a large selection of polishing stones then if it is that bad in the seat it will leak still leak. Hope you get it buddy they have whipped more than one good man.
                            Rodan
                            1980 G Silverbird
                            1198 Overbore kit
                            Grizzly 660 ACCT
                            122.5 Main Jets
                            ACCT Mod
                            Mac 4-2 Flare Tips
                            Antivibe Bar ends
                            Rear trunk add-on
                              • 8061
                              Mike's XS has the appropriate manual petcocks. $100 for a pair.
                              http://www.mikesxs.net/parts/yamaha-...47-24500-02-00
                              Parts-n-More has universal petcocks for $60 a pair. They have the required adapter plates as well.
                              http://www.partsnmore.com/parts/yamaha/xs1100f/?filters[category]=carb&filters[fitting]=universal
