Where do these carb washers go!
  • neJeff
    • Jun 2011
    • 346
    • Nebraska
    I took these apart over a year ago and don't know where they go! They are not the drain bowl washers. Do they fit under the pilot cover screw or in that circular area?
    Help!
    Current Daily Rides / Projects
    1979 Yamaha XS1100F (since 2015)...Project
    1980 Suzuki GS850G (since 2012)
    1979 Kawasaki KZ400B (since 2013)
    Main Jet?
    If not the bowl drain, then they look like they are the washers in the main jet tower. They fit snugly in underneath the main jet.
    • neJeff
      • Jun 2011
      • 346
      • Nebraska
      The main jet has it's washers already
      • neJeff
        • Jun 2011
        • 346
        • Nebraska
        Oh, and I should say this is a 78' standard.
        • neJeff
          • Jun 2011
          • 346
          • Nebraska
          i found this old thread of TopKats with a cut away of a 78/79 carb. It appears to me that that the tower cap screw over the pilot jet DOES have a washer.
          What do you guys think?
          • mack
            • 2411
            • Ontario, Canada
            Washers
            If they are fiber style, they belong under the fuel valves. If you bought K&L fuel valves and needles, they came with thin aluminum washers attached. These would be surplus, but the fiber are much better than the aluminum.
            mack
            79 XS 1100 SF Special
            HERMES
            original owner
            81 XS 1100 LH MNS
            SPICA
            78 XS 11E
            IOTA
            https://youtu.be/wB5Jfbp6SUc
            https://youtu.be/RaI3WYHSuWA
            Frankford, Ont, Canada
            613-398-6186
            • neJeff
              • Jun 2011
              • 346
              • Nebraska
              The fuel valves have their fiber washers in place
                Yes, they are the pilot tower washers.
                Nothing goes that recessed circular area in your pic.
                • Dbshea
                  • Mar 2016
                  • 133
                  • Muskego, WI.
                  Agreed. There should be a washer under that tower screw
                  79 F
                  • mack
                    • 2411
                    • Ontario, Canada
                    mine
                    are metal washers and are no larger than the tower circumference. Could be that the originals were lost over the years during previous cleanings.
                    mack
                    HERMES
                    original owner
                    81 XS 1100 LH MNS
                    SPICA
                    78 XS 11E
                    IOTA
                    613-398-6186
                    • neJeff
                      • Jun 2011
                      • 346
                      • Nebraska
                      Thanks guys! Finally going to get this thing started for the first time in many years!
