Petcock
  • MichaelisEvolving
    • Jul 2014
    • 52
    • Tampa, Fla.
    Petcock
    So I was painting my gas tank on my xs1100 and changing out the old fuel lines when I realized something and I was hoping someone could help me to make sure it's right. So I noticed on the left petcock that the copper parts of it where the gasoline comes out has two but the right side only has 1 where fuel comes out and the other is like a plug. I'll attach pictures so you can see what I'm talking about and I'm wondering why it's like that or if it's suppose to be something else.
    79 XS 1100 midnight special frame with an 81 XS 1100 engine or as I like to call it "Mad Max".
  • MichaelisEvolving
    • Jul 2014
    • 52
    • Tampa, Fla.
      There are supposed to be 2 nipples on the petcocks. I am.guessing one of the nipples was loose or came out so someone sealed it off rather than fixing it.
      Not 100% sure on this but I believe on the special petcocks the front nipple is prime and the rear is on/prime.
      • Prisoner6
        • Aug 2013
        • 1184
        • Phoenix, AZ
        Originally posted by natemoen
        ... Not 100% sure on this but I believe on the special petcocks the front nipple is prime and the rear is on/prime.
        On Special petcocks the front nipple is PRIME and the rear nipple is ON/RESERVE.
        Marco
        1979 Honda CBX
        2002 Kawasaki ZRX1200R
        WE MISS YOU, DON
          Yup, that's what I meant, why would there be 2 prime nipples.
          • MichaelisEvolving
            • Jul 2014
            • 52
            • Tampa, Fla.
            Well I've been trying my hardest to find new petcocks I could put on my tank but I can't seem to find xs1100 special ones. I don't want to buy other ones that won't fit or aren't right. I have seen some for 650 but if anyone knows of any alternatives please let me know.
            • MPittma100
              • Aug 2011
              • 2359
              Petcock Alternatives
              One of my bikes has the Pingle petcocks on it. They are single line, On-Reserve-Off. They work well and are simple. They require an adapter, available also from Pingle, to fit the Yamaha tank. They are nice, but not cheap. Kits and Yamaha petcocks are available on eBay. Follow this link to see the Pingle valves:
              Manufacturer and distributor of high performance motorcycle parts and accessories for street and drag. Find fuel valves (petcocks), wheel chocks, air shifters, all electric shifter kits, wheelie bars and more here. Products for Yamaha, Harley-Davidson, Kawasaki, Suzuki and Honda available.
              1981 XS1100H Venturer
              K&N Air Filter
              ACCT
              Custom Paint by Deitz
              Geezer Rectifier/Regulator
              Stebel Nautilus Horn
              EBC Front Rotors
              Limie Accent Moves On In 2015
              Mike
                Hey Michael,
                Here's a thread Mack posted a few weeks ago about a generic petcock that can be fitted to our tanks with a little modification and an adapter plate. His example is a Standard, but all you have to do is get the petcock that fits the special screw spacing of 34mm.
                The petcock he found was still a bit $$ at $40.00. I found some decent single output types with Run/Stop/Reserve in the 3/8" NPT fitting style for under $20.00 on eBay with free S&H. You can get an adapter plate from Partsnmore.com for this type for about $8.00 +S&H, and even a petcock, but they are closer to the $40.00 price Mack showed.
                Petcock/adapter plate? 34 mm C2C $8.50 #20-0101
                Universal 3/8" NPT petcock # 20-0100 $30.00.
                  • 8798
                  It is possible to run just one tap on the left side and block off plate on the right side of the tank. Just put a T in the line feeding the 2 carb inlets. I run both my bikes this way, no ill effects.
                  • vedgar
                    • 311
                    • Clarkston, Michigan
                    I have some, give me a pm
                    might have two petcocks. You will need a left and a right.
                    79 1100 SF Carmine Red stock
                    85 Honda v65 Magna
                    • MichaelisEvolving
                      • Jul 2014
                      • 52
                      • Tampa, Fla.
                      Thanks for all the responses! I'm gonna look at some and I'll post them on here and you guys can maybe look at them and see if they work? That way I don't buy some that end up not working out. Especially at $40 a pop.
                      • MichaelisEvolving
                        • Jul 2014
                        • 52
                        • Tampa, Fla.
                        I was looking at these and hoping they would either fit or wouldn't require too much adjusting to make it work.
                        • MichaelisEvolving
                          • Jul 2014
                          • 52
                          • Tampa, Fla.
                          Also if anyone had a website to order the plates I'll most likely need from, I'd greatly appreciate it
                            Hey Michael,
                            If your bike has a Special Tank, those petcocks won't work, they have the wrong mounting hole spacing of 43mm vs. the Special's 34 mm.
                            And in my post #8 I mentioned the website for the adapter plates, but left off the WWW. so it didn't show as an active link: www.partsnmore.com
                            Remember, these are adapter plates for the Universal 3/8" NPT type fitting. Search for that with petcock, and you should find plenty.
                            • MichaelisEvolving
                              • Jul 2014
                              • 52
                              • Tampa, Fla.
                              This is perfect! Thanks.
