New to the Forum
    That fule level jig is, like, totally tubular! I want one!
    The levels and plugs are close enough I'd leave the floats alone and just ride the snort out of it for a hundred thousand miles or so. Recheck the levels every now and then just to show off the jig and to make sure they don't creep up or down.
    • Loch
      XSive(Resigned)
      • 49
      • Corpus Christi, TX
      bike looks great. make sure fuel lines are under projection on air cleaner, the bend in the fuel line going across the top is enough to cause low fuel flow. i'm refering to the few inches of line coming off the petcocks
      Resigned
      • SouthernGrey64
        • May 2016
        • 40
        • Marietta, GA.
        Gonna go ride now!!
        3Phase- Thanks for confirming that the fuel levels and plugs look OK. I definitely will be putting some miles on it now!
        Also, the jig is simple to make. Its just two pieces of scrap aluminum bolted together-one bent at 90 degrees and the other with 4-1/4" holes for the clear tubes. The screw in upper part of the vertical piece has a 1/2" piece of 1/4" tubing that fits into the unbored vent hole on the left side of #1 carb. When the screw is tightened, the tubing expands and hold the jig tight.
        Loch- Thanks. I am real happy with the way it turned out. I am using the OCTI with L-1200 Tygon fuel lines and have routed them so as to avoid tight bends that could restrict fuel flow. Also, put two in-line filters in just before the fuel inlets.
        Thanks again,
        Linwood
        1979 XS1100SF
        Original Owner-purchased January 1980
          Schweet!
          Quixotically, the lowest fuel level is on carb #1 but #1 plug is the darkest while carb #3 has the highest level but #3 plug is the lightest -- ride it!
          • SouthernGrey64
            • May 2016
            • 40
            • Marietta, GA.
            #35
            Hot Fuse Block
            I have been riding the bike now on several local test rides and it has been performing great! Thanks to all of you who gave me help and encouragement in getting this thing running again after all these years. This site is awesome!!
            After coming home from a test ride yesterday, I turned the engine off with the kill switch so I could aim the headlight and adjust the rear brake light switch. After aiming the headlight, I left it on along with the ignition switch so I could check when the brake light came on. With the right side cover off, I accidentally touched the fuse block cover. It was real warm. So, I took it off to see what was going on. The fuses were so hot that I could barely touch them without burning my finger.
            As a part of the restoration, I cleaned all of the electrical connections and the fuse clips with contact cleaner. The fuse clips don't show any discoloration or distortion, are clean, and hold the fuses tightly. Is this normal?
            1979 XS1100SF
              #36
              Hey Grey,
              Heat is not normal for the fuseblock, especially the old OEM style brass clips and glass fuses!!! Heat = resistance and loss voltage/amps. The old clips weaken, corrode, break, etc., and the glass fuses can go bad and still look good from the outside. This is why we highly suggest doing the ATCO/Solid style fuse block MOD to help eliminate this as a source for electrical gremlins!
              See this FORUM and review the several tips about fuseblocks:
              See this for how to acquire a replacement fuseblock and connectors:
              • SouthernGrey64
                • May 2016
                • 40
                • Marietta, GA.
                #37
                Ordered Fuse Block
                Thanks TC,
                I knew that I would need to make the fuse block mod at some point from my readings on the forums. Noticing how hot the fuse block was the other day just sped up my decision to go ahead and do the mod now.
                I just sent you an order for the fuse block and 12 terminals.
                Thanks again,
                Linwood
                1979 XS1100SF
                • MPittma100
                  • Aug 2011
                  • 2359
                  Direct battery ground
                  Originally posted by SouthernGrey64
                  Thanks TC,
                  Thanks again,
                  Linwood
                  Heat in the electrical system is a result of high resistance. Either poor ground or corrosion in the connectors.
                  Check all of the connectors especially ones behind fuse panel for corrosion.
                  Improve chassis grounds to direct battery grounds by adding wire between chassis ground points making a direct battery ground. Chassis grounds are poor grounds.
                  1981 XS1100H Venturer
                  K&N Air Filter
                  ACCT
                  Custom Paint by Deitz
                  Geezer Rectifier/Regulator
                  Stebel Nautilus Horn
                  EBC Front Rotors
                  Limie Accent Moves On In 2015
                  Mike
                  • SouthernGrey64
                    • May 2016
                    • 40
                    • Marietta, GA.
                    #39
                    Ground Connections
                    MPittma100,
                    I cleaned all of the connectors during the restoration but didn't check the ground points. I'll check and clean them tomorrow and run "home run" ground wires back to the battery ground point. What size wire do I need to use?
                    Thanks for the advice!
                    Linwood
                    1979 XS1100SF
                      • 7831
                      Clean the grounds and put anti-seize on them to keep them clean. A 12 gauge wire from the battery to the screw on the Reg/Rec the other grounds go to should take care of the ground problem.
                      • MPittma100
                        • Aug 2011
                        • 2359
                        MPittma100,
                        Linwood
                        Use similar size of existing battery cable - 8 or 10 gauge. 12 will also work. Simply eliminate your chassis as a ground. You will see the difference.
                        K&N Air Filter
                        ACCT
                        EBC Front Rotors
                        Mike
