I suggest removing the round ignition cover on left side, then using two hands try to pull apart every inch of each of those pick-up coil wires. If insulation stretches on a wire doing that, internal wires are broken. Cut wire, slip a small piece of shrink tubing up on either cut wire. Use a really short(1/4") naked butt connector to re-attach wires and slip shrink tubing over it(soldering wire together is ill-advised). My bet is white wire would be the one with the broken internal wires
. Tis a common issue since the centrifical advance and vacuum advance assembly constantly rotate that assembly back and forth causing wires to constantly be in motion.
