Diaphram leaking.
  • dbmb0416
    • Jun 2015
    • 128
    • Westdale Ny
    Where can I get a restrictor for the line? And thanks bikerphil for the tip.
    79 XS11SF
      • 8892
      You could use a carb pilot jet, stuff it down the line. I took a piece of round plastic rod about 1/4" long and drilled a tiny 1/32" hole down the center. They are used in aquarium air pump lines so maybe pet store may have something. You may not need to use one, check it first without it, put your hand on the valve while bike is idling and check for pulse vibration. It would only pulse at low engine RPM.
      • dbmb0416
        • Jun 2015
        • 128
        • Westdale Ny
        Thanks again My Friend
        79 XS11SF
          • 8892
          You bet, good luck!
          • dbmb0416
            • Jun 2015
            • 128
            • Westdale Ny
            It was my second day of vacation. Now it's just sitting there waiting for the part. But again she got me home before she started leaking.
            79 XS11SF
            • mlew
              • Jun 2005
              • 226
              • Apex , NC
              When you install your new unit, check to see if it is pulsing with the engine vacuum pulses. It can destroy itself prematurely if pulsing, but adding a restrictor in the vacuum line will eliminate this. I have had this problem with the Pingel aftermarket vacuum fuel valve, I think it could also happen with the OEM.
              There is a restrictor built into it. Take the vacuum nipple off and inside there is a small disc that acts like a restrictor/check valve. Its also possible someone removed it so it won't work.
              Slow down and enjoy life. If you are in that much of a hurry, you should have left eariler.
              Current rides:
              80 XS1100SG
              82 JX1100
              83 Venture Royale
              86 V-Max
                • 8892
                Ah, that's good to know Mark. I vaguely remember seeing something like that in the OEM valve, it's been so long since I rebuilt one of those. Thanks for the info.
                • dbmb0416
                  • Jun 2015
                  • 128
                  • Westdale Ny
                  Yes Thanks. Learning more and more each day.
                  79 XS11SF
                  • mlew
                    • Jun 2005
                    • 226
                    • Apex , NC
                    Pick our brains and we will ooze information gladly.
                    Current rides:
                    80 XS1100SG
                    82 JX1100
                    83 Venture Royale
                    86 V-Max
                    • dbmb0416
                      • Jun 2015
                      • 128
                      • Westdale Ny
                      Part on. No leaks and no pulses. Did have one carb float stick and leak. But luckily a tap on the carb and it unstuck. Thanks again for all tips.
                      79 XS11SF
