Put my carbs back on recently after a cleaning which they really didn't need...spick and span clean.
Started right up as if it ran yesterday (it's actually been about a year). Then within 5 or 10 seconds the revs suddenly shot Way Up and I turned the key off right away. Whatever is going on now, started right then.
It's now 99% dead. No headlight. Only thing happening is a faint brief glow of the oil light and neutral light when the key is turned on. Also a barely audible squeak from the horn. Battery is very new...12.7 volts.
It's always on a Deltran Battery Tender.
Fuses are fine (TC's fusebox), including the main glass fuse on the left side.
I now do not know what to check/do and want to get this thing going.
I know you all can point me in the right direction!!
Double check that thing, pull it out, pul on both ends of the fuse, put an Ohmmeter on it, make sure it has continuity, or replace it. You need to get a single ATCO solid fuse holder and wire that thing in there in place of that glass one!!! Make sure it's rated for 30 amps!
