Kickstarter
  • Sup3rman86
    • Jun 2016
    • 19
    • Omaha, NE.
    Kickstarter
    I am going to be installing a Kickstarter in my 81 xs1100 and I need to know where I can find a kick start oil seal that will fit....any suggestions?
    81 SH
    • 1224
    • Peachtree City, Georgia.
    Partzilla Has it new....
    http://www.partzilla.com/parts/searc...TER/parts.html
    OIL SEAL
    93102-20108-00
    $4.39
    All the side covers are the same. The seal above is for a '78. Will fit any of the side covers.
    KURT
    • Sup3rman86
      • Jun 2016
      • 19
      • Omaha, NE.
      Thank you!
      81 SH
        Hey there,
        Have you done the research on what's involved in adding the kickstarter? There are major pieces missing in the starting driveline that you'll need to acquire other than just the main shaft. Plus, I've heard/read that you have to split the cases to gain access to the other parts behind the case!
        Finally Yamaha did away with the kickstarter in the later years because it was mostly unnecessary. The ignition system is voltage dependent, and when the battery gets weak, the ignition won't fire the plugs even though it may have enough juice to crank the engine, it won't spark, so no start. Granted a few folks have reported being able to kick start their bike when their battery was too low to start electrically, but if the battery runs down just below ~10.5 volts, then even with the kickstarter, you won't be able to start it!?
        Okay, good luck! T.C.
          • 1224
          More than just a kicker shaft & spring....
          SNIP.... Plus, I've heard/read that you have to split the cases to gain access to the other parts behind the case! SNIP....
          Actually, that's not the case (LOL). All the necessary parts can be added from the side cover or oil pan without splitting the cases. Done it!
          The '81 will be a little harder to add the kicker to than the '80 would be. I've pulled apart AT LEAST five '80 motors and they all had a FEW of the necessary pieces. I've read that those few pieces that were left in there in '80 were not in ANY of the '81s. I do not know that for certain... only what I've read.
          I have added a kick starter to TWO of my XS11's so I have been there and done that. I'll probably never use them....but they do look cool.
          You can use the Partzilla parts page link I provided for the oil seal to make sure you have everything needed. There are MANY folks that buy the kicker shaft & spring assy. on Evil-Bay and THINK that's all they need to add this assy. There is AT LEAST another dozen pieces needed!
          Additionally, the shaft on the stock kicker assy. is not designed for a standard hinged kicker (i.e. XS750 or 850). There is no machined groove for the clamp bolt. It is not too hard to modify an XS750/850 kicker to work but if you have an aftermarket exhaust it might not swing out far enough to clear it.
          There are a BUNCH of things necessary to install the kicker....be prepared!
          KURT
