carb install
Originally posted by DeanR View Post81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.
Already lubed up but the snorkels will not move into position.
I'm thinking that I may have had the airbox in a slightly different position? I do know that someone posted a tip that did the trick last year!80 SG
81 SH in parts
99 ST1100
91 ST1100
Hey Dean,
Get out your blowdryer and heat them up a bit, that's what makes them more pliable and bendable so you can get them past the mouth/inlet of the carbs. That's what I remember being posted about them.
T.C.T. C. Gresham
Dean
I've always found the having the upper air box in position firstbut pulled back away from the carbs is required. Then you side the carbs in at an angle with the bells tipped up across the tops of the snorkel till you have them lined up with the intake boots slide the boots in first then push the bells down till they line up with the snorkels, then just articulate the airbox a bit until it slips over the carb bells.mack
79 XS 1100 SF Special
HERMES
original owner
81 XS 1100 LH MNS
SPICA
78 XS 11E
IOTA
https://youtu.be/wB5Jfbp6SUc
https://youtu.be/RaI3WYHSuWA
Frankford, Ont, Canada
613-398-6186
Well, turns out that the positioning in the photo was fine, The all important 'tip' of last year was to not be shy about shoving the snorkel down in front of the battery. But that's kinda difficult when those two little screws on the sides of the airbox are still screwed into their spot.
Anyway, all seems to be back together. Now just have to put the bone dry tank on, get some gas and go for a ride down the street if it starts up ok.80 SG
81 SH in parts
99 ST1100
91 ST1100
Started right up as if it ran yesterday (it's actually been about a year). Then within 5 or 10 seconds the revs shot way up and I turned the key off right away. It's now 100% dead, with the key doing nothing.
Fuses look fine and I now do not know what to check/do.80 SG
81 SH in parts
99 ST1100
91 ST1100
Hey Dean,
Doesn't your bike have the separate main fuse on the other side??
Check your main ignition switch, also the emergency stop/run switch!
Can't remember if you did the Solid ATCO fuse mod or are still running the OEM glass ones!?
T.C.T. C. Gresham
