carb install
  • DeanR
    • Jan 2005
    • 1486
    • Finger Lakes NY
    carb install
    Took these off and on a couple times last year. Can't remember the damn trick to get the airbox connected. It just misses for clearance, and won't move any more.
    80 SG
    81 SH in parts
    99 ST1100
    91 ST1100
    .....airbox snorkals rotate a bit in order to align all four on carb bells. Before slippin' that airbox on, spray a bit of silicone lube spray inside those carb/filter boots.
    • DeanR
      • Jan 2005
      • 1486
      • Finger Lakes NY
      Already lubed up but the snorkels will not move into position.
      I'm thinking that I may have had the airbox in a slightly different position? I do know that someone posted a tip that did the trick last year!
      80 SG
      81 SH in parts
      99 ST1100
      91 ST1100
        Hey Dean,
        Get out your blowdryer and heat them up a bit, that's what makes them more pliable and bendable so you can get them past the mouth/inlet of the carbs. That's what I remember being posted about them.
        • mack
          • 2411
          • Ontario, Canada
          Dean
          I've always found the having the upper air box in position firstbut pulled back away from the carbs is required. Then you side the carbs in at an angle with the bells tipped up across the tops of the snorkel till you have them lined up with the intake boots slide the boots in first then push the bells down till they line up with the snorkels, then just articulate the airbox a bit until it slips over the carb bells.
          mack
          79 XS 1100 SF Special
          HERMES
          original owner
          81 XS 1100 LH MNS
          SPICA
          78 XS 11E
          IOTA
          https://youtu.be/wB5Jfbp6SUc
          https://youtu.be/RaI3WYHSuWA
          Frankford, Ont, Canada
          613-398-6186
          • DeanR
            • Jan 2005
            • 1486
            • Finger Lakes NY
            Well, turns out that the positioning in the photo was fine, The all important 'tip' of last year was to not be shy about shoving the snorkel down in front of the battery. But that's kinda difficult when those two little screws on the sides of the airbox are still screwed into their spot.
            Anyway, all seems to be back together. Now just have to put the bone dry tank on, get some gas and go for a ride down the street if it starts up ok.
            80 SG
            81 SH in parts
            99 ST1100
            91 ST1100
            • DeanR
              • Jan 2005
              • 1486
              • Finger Lakes NY
              Started right up as if it ran yesterday (it's actually been about a year). Then within 5 or 10 seconds the revs shot way up and I turned the key off right away. It's now 100% dead, with the key doing nothing.
              Fuses look fine and I now do not know what to check/do.
              80 SG
              81 SH in parts
              99 ST1100
              91 ST1100
                Hey Dean,
                Doesn't your bike have the separate main fuse on the other side??
                Check your main ignition switch, also the emergency stop/run switch!
                Can't remember if you did the Solid ATCO fuse mod or are still running the OEM glass ones!?
