A little help given
So i got a chance to stop by today for about an hour and helped TC get the engine into the frame. He'll be quite busy putting the rest together. I told him I'd stop by tomorrow afternoon and see if he needs more help.
Anyways, they made the lower portion just a few mm's too wide, had to cut/grind a bit off of the inside of the FRAME mounts to allow them to fit, but were able to do so!
Needless to say that set me back another 1/2 hour flipping the tire around, and THEN another half hour chasing all of the little friggin' balance beads that fell out!!
Also, need to put the new oil filter and fill it back up with fresh oil, and get a nylon washer for the drain plug! Tomorrow I'll be getting the harness and wiring all done. I still need to get the backrest made and fitted to the saddlebag/trunk frame mount. I don't know if I'll have time to MOD the footrests in time for the trip!? Also need to put the petcocks on the tank, gas cap, and carbs and get them on and hooked up. Also need to put the intake boots, exhaust on. Also the LED headlight bulb swapped into the housing, and also the AUX LED lights mounted. But the TO DO list is getting much shorter!!!
