Hey guys Im contemplating either selling my really clean 80 eleven special, or rebuilding it. I need some guidance though. Cylinder #2 started to oil foul plugs. So bad that there is smoke now on startup and while driving, when I rev it up oil shoots out of the exhaust. I did a hot compression test I got 125psi.
My question to you guys is how hard is to to remove the cylinder heads while leaving the block in the bike?
And would it be worth ripping the entire top end apart to drop in that 1196 ebay big bore kit to fix the problem? Seeing as its only $150+machining+labor.
I do not want to rebuild the entire engine. I just figured installing that big bore kit will take care of my problem, give me fresh bores, fresh pistons, and I could lap and change the valve seats out while im there.
Should I even dig into the bike that far? Or just part it out? Thanks.
