Engine rebuild
    • 1262
    • Peachtree City, Georgia.
    Originally posted by e30 gangsta
    That's a genius idea!
    Unfortunately, the credit goes to Clymer. It is a great idea....
    Kurt
    1982 - CBX1000 - Honda
    • ViperRon
      • Feb 2011
      • 1062
      • Woodstock, VA
      An alternate method is to install pistons in cylinders and then all you do is is slide the wrist pins in and put the one remaining keeper on. It is easier than fighting a tight set of rinds in and you can be sure you do not break a ring. The one thing I definitely suggest is to replace the crank seals if there is any leakage. There are seals you can get to put in that do not have the lip and you drive them in.
      Rodan
      1980 G Silverbird
      1198 Overbore kit
      Grizzly 660 ACCT
      Barnett Clutch Springs
      R1 Clutch Fiber Plates
      122.5 Main Jets
      ACCT Mod
      Mac 4-2 Flare Tips
      Antivibe Bar ends
      Rear trunk add-on
      • e30 gangsta
        • Mar 2016
        • 142
        • Lone tree, Colorado
        The bike leaked no oil at all. No visible oil from the outside. I assume the seals are good then.
        80 XS1110 SG, RD400
        • e30 gangsta
          • Mar 2016
          • 142
          #34
          Hey guys im looking for that big bore kit that was sub $200 for the set of pistons, but I cant find them anymore? Anyone got a link?
          80 XS1110 SG, RD400
            I noticed it was gone too. You can try to contact the seller to see what's up....... http://www.ebay.com/itm/131171371567...%3AMEBIDX%3AIT
              #36
              I found the kit being RESOLD/Retailed by SpeedMotoco for $250.00, probably S&H extra!? They are the same CAST type, not forged.
              Speed Moto Co All Motorcycles Parts shop for Cafe Racers , Mikuni Carburetors, Motorcycle Headlights, Bobber & Chopper , Vintage, Modern Motorcycles, Harley Davidson Parts
              I also found this listing on the UK site with statement, explanation that the item was no longer available...which makes me think that they sold OUT of their production....and if so, I would think they would realize that they will SELL, and will probably put them back into production!?!?
              http://www.ebay.co.uk/itm/80-81-Yama...-/131171371567
              Greg, I didn't actually click on your link until after I submitted this one! Yours says the same thing, but I also noticed that they sold 35 of these kits, so again I would think that they will probably make more, just don't know how soon??
              • ViperRon
                • Feb 2011
                • 1062
                • Woodstock, VA
                #37
                TC When I got the kit I have it came from Japan, the guy said it was old warehouse inventory. The pistons had Yamaha tuning forks molded into them I doubt a remanufactured parts would come that way.
                Rodan
                1980 G Silverbird
                1198 Overbore kit
                Grizzly 660 ACCT
                122.5 Main Jets
                ACCT Mod
                Mac 4-2 Flare Tips
                Antivibe Bar ends
                Rear trunk add-on
                • e30 gangsta
                  • Mar 2016
                  • 142
                  #38
                  Thanks viper I will contact the company to make sure they actually have them in stock thank you!
                  80 XS1110 SG, RD400
                  • e30 gangsta
                    • Mar 2016
                    • 142
                    #39
                    Alright guys finally got the motor ripped down. Head and jugs are off as well as the pistons.
                    Any tips on how to clean the base gasket surface?
                    Would taking out the studs make cleaning that surface easier?
                    To pull the studs out just do the double nut method and back them out? Thanks.
                    80 XS1110 SG, RD400
                      • 4015
                      I'd be very weary pulling those studs out. I'm at the same point as you. I bought some Permatex gasket remover from Advance Auto, and have a gasket scraper from Sears. However, I plan on using a metal putty knife and window scraper, as the gasket scraper was knicking the surface.
                      My studs are pretty ugly, so I plan on sanding those down, so the jugs and head go back on smoothly.
                      • e30 gangsta
                        • Mar 2016
                        • 142
                        #41
                        I was thinking along the same lines as you. Also thinking of using a 3M Bristle Disc. Any ideas on how to cover the holes so all the junk doesn't fall into the holes/crankcase? I was thinking of just stuffing them with clean shop rags.
                        80 XS1110 SG, RD400
                          • 4015
                          Yes, I'll lay some painters tape across the holes.
                          • e30 gangsta
                            • Mar 2016
                            • 142
                            #43
                            Also I was thinking of flushing the crackcase, to get whatever little pieces of dirt and what not that fell in out. Any suggestions on what fluid to do it with? maybe a gallon of cheap oil?
                            80 XS1110 SG, RD400
                              I would use diesel fuel, wouldn't hurt anything in there.
                              • e30 gangsta
                                • Mar 2016
                                • 142
                                #45
                                Will do diesel fuel sounds like the plan. So as far as engine gasket sets go, there is a couple of sets on ebay. Is there a specific brand that you guys recommend? Id like to purchase one of the kits that's the best quality thanks!
                                80 XS1110 SG, RD400
