79 XS1100SF Rear Brake M/C Kit (Rear)
  • underdog57
    • 321
    • Alburgh , Vermont,054
    Hi ,
    I just was putting K&L kit 32-4033 in and the piston section fits fine . But the O.D on the last step of the piston is too large and will not slide in the bore .
    Guessing a manufacturer error ?
    First time doing the brakes , all are done but stuck on this .
    Might get this one turned on a lathe as everything else matched up
    Any one else run into this ?
    Thanks for reading
    Bob
    1979 XS1100 SPECIAL (under 18,000 miles Sold 5/12/2016
    1982 XJ1100 MAXIM(PARTS BIKE??)shows 14,000 miles ??? Up for sale whole or parts
    Originally posted by underdog57
    Hi ,
    Thanks for reading
    Bob
    Unfortunately K&L should be the key answer. Quality control is definitely lacking.......and BTW, K&L jets are to NEVER be substituted for Genuine Mikuni jets.
    • underdog57
      • 321
      Carbs beem done a few years back , the new kits were pretty poor for jets I found also ..
      Might get the piston turned down to size , just want it done ...
      All the other kits for the brakes were pretty good
      Thanks for the reply
      Bob
      • underdog57
        • 321
        Mikuni Jets
        Are genuine Mikuni jets still available , I thought they were extinct ..
          • Prothec
            • Jul 2007
            • 587
            • Fort Myers, FL
            That should be the kit for the 1/2" bore MC, so it should, at worst, be too small if you had a 14mm MC. I've never had one not fit. If it's a quality control issue, I'd hope wherever you bought it from would just replace it without much hassle.
            Website/Blog
            • underdog57
              • 321
              The piston fits in perfect till you get to the last step which should be the same od as the rest of it ..
              the seller has asked if I called tech support to the product ..
              • Prothec
                • Jul 2007
                • 587
                • Fort Myers, FL
                The part looks like this, right? Do you still have the old piston to measure against just to be sure? If all else fails and it's truly a manufacturing defect, I can't imagine they wouldn't replace it.. www.klsupply.com
                Website/Blog
                • underdog57
                  • 321
                  brake xs1100s
                  yes , looks just like that , came in factory package . the last step should be the same od as the parts the seal are near , its not ...can mike it too be sure . sure seems like its bottoming at that point . the old piston is very corroded .
                  I do have an XJ1100 parts bike to look see if the piston is the same ...
                  thanks for the suggestions ,
                  bought from an Amazon seller so 100% will get money back
                  Bike is held back w this though
                  • underdog57
                    • 321
                    measured the sections
                    Ok , measured and the piston by the cup is .499 " the faulty new part has .515 at the last shoulder ...
                    the old piston as best I can read is .499 at the same section
                    Will pas this along to the seller and ask for a return
                    Thanks Xsively
